Old 06-21-2017, 11:28 AM   #15
btan219
Drives: DGM 15' BRZ Limited
I will see if I can dig up a diagram for you. It is pretty tight to try and work on the tank itself but the rest should be too bad.
Awesome thank you. idk anything about cars but since I got my BRZ a few months ago I've been trying to learn more about it and cars in general by working on things myself (adjusted my clutch the past weekend and it was a huge accomplishment for me lmao). The issue with my wiper fluid will be another learning experience I can add to my knowledge database whether I can fix it or not
btan219 is offline   Reply With Quote
Old 06-21-2017, 11:33 AM   #16
jasonojordan
Drives: 2013 satin white brz limited
If its not coming out of either side I would start at the tank and pump and work my way back before removing the cowling. Sorry for the misunderstanding.
jasonojordan is offline   Reply With Quote
Old 06-21-2017, 11:36 AM   #17
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
Before you start taking stuff apart, you can separate the line here and see if anything is coming out:
BRZyJ is offline   Reply With Quote
The Following 3 Users Say Thank You to BRZyJ For This Useful Post:
humfrz (06-22-2017), jasonojordan (06-21-2017), Tcoat (06-21-2017)
Old 06-21-2017, 11:40 AM   #18
Perfect! That will reduce the number of possibilities even more.
Old 06-21-2017, 12:33 PM   #19
btan219
Thanks so much for the diagram! I'll update when I get a chance to work on it.
Old 06-21-2017, 01:37 PM   #20
humfrz
By nozzle do you mean where the water comes out from by the window? If so, then yes I've already ran a pin through those two holes and still nothing.
Also, what is the line everyone talks about? This is my first car and idk anything about cars or their components if you can be more specific please. Once I spot it I'm not really sure what to be checking for. Everyone's just saying to check if it's ok, but idk what looks ok and what doesn't. Please explain like I'm a 5 year old lol
The line we speak of is a soft, black, plastic tube, about 1/4" in diameter. It runs from the nozzles to the pump/washer container.
It starts (or ends) at the nozzles (hidden under that black plastic screening where the nozzles are, up to the pump (running along the top of the front left wheel well).
I'm getting the feeling that you may need someone to help you or take it to the dealer or a shop and have them fix it.
humfrz
Old 06-21-2017, 02:00 PM   #21
btan219
humfrz
lol I want to try it out myself first and learn. If not, ya I'll take it to a shop when I have time
Old 06-21-2017, 02:34 PM   #22
It is almost the perfect first DIY repair you can do on a car. There is very little real damage you could possibly do.
Old 06-21-2017, 02:41 PM   #23
jasonojordan
Not to mention the best part...The car still runs so if you can't figure it out right away no big deal keep trying since your not out a car.
The Following User Says Thank You to jasonojordan For This Useful Post:
Tcoat (06-21-2017)
Old 06-21-2017, 02:42 PM   #24
btan219
That's what I was thinking. I rarely ever even use the washer fluid anyways so if it never gets fixed I'd be ok with it and just having a microfiber towel and glass cleaner in my trunk for when I really need to wipe something off. Though I'll probably take it to a shop if I can't do it
Old 06-21-2017, 02:51 PM   #25
LOL Ya I just noted your location.
I can go through a gallon a week for 5 months of the year and it is critical that it works!
Old 06-22-2017, 07:09 PM   #26
btan219
http://imgur.com/a/kaEgo
I disconnected the two lines but nothing still came out
Old 06-22-2017, 07:43 PM   #27
BRZyJ
BRZyJ's Avatar
That sucks...if you can hear the pump working and nothing is coming out of that loose end of the hose then it's gotta be a kink or a clog on the pump/reservoir side of things, I would think. Unfortunately there's not really any room to follow that line very far...might have to remove at least the headlight.
Old 06-22-2017, 08:21 PM   #28
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Has the OP checked for water in the fluid reservoir.?
Not being facetious but I'm getting a bit jaded by the dimfuck posts on here.
Scrappydoo is offline   Reply With Quote
Washer fluid tank, need to fix asap. SavingManuals Electronics | Audio | NAV | Infotainment 0 11-22-2015 07:12 PM
Window washer fluid light? husker741 Scion FR-S / Toyota 86 GT86 General Forum 14 10-20-2013 01:15 PM
Washer Fluid Indicator Tdot BRZ First-Gen (2012+) — General Topics 58 02-19-2013 05:02 PM
Deos this car not warn you when you are low on washer fluid? NOHOME Scion FR-S / Toyota 86 GT86 General Forum 28 02-07-2013 01:00 AM
FYI - Washer Fluid light Ben_G BRZ First-Gen (2012+) — General Topics 48 01-03-2013 05:18 PM
