Old 06-15-2017, 11:11 AM   #15
Veeoh
Veeoh's Avatar
I'm running the H&R super sport springs. Have them on my car for about a year now and I gotta say I don't have any complaints on them. The roads in my area aren't bad which is great, but when I go into DC there's holes everywhere and to me it just feels a bit stiffer than stock. The height of my car is perfect too.
Veeoh is offline   Reply With Quote
Old 06-15-2017, 11:42 AM   #16
JD001
JD001's Avatar
Drives: Subaru BRZ
I have Sportlines and when installed the alignment was done too. No camber adjustments though.
The car looks great but the travel is short so I need to be careful going over potholes. Not had issues with speed bumps (touch wood).
Old 06-15-2017, 12:49 PM   #17
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
RCE yellow springs
Jfheisenberg is offline   Reply With Quote
The Following User Says Thank You to Jfheisenberg For This Useful Post:
smg1138 (06-15-2017)
Old 06-15-2017, 01:45 PM   #18
SwaggFPS
SwaggFPS's Avatar
Drives: 2016 BRZ Limited
RCE Yellows. Just hope you have an impact gun, if you're doing it yourself. If not, and not taking it to a shop, you'll need 2 allen wrenches, socket with hole on the side for one of the allen wrenches, and a small towel (your palms will thank you for it lol). This is to remove the top hats.
I did it myself without an impact, took longer than it should have. Also, if your arms are long enough, you can remove the rear strut by yourself.
Mid-TN
SwaggFPS is offline   Reply With Quote
The Following User Says Thank You to SwaggFPS For This Useful Post:
strat61caster (06-15-2017)
Old 06-16-2017, 05:07 PM   #19
Darkrune
Darkrune's Avatar
Drives: 2017 86
Even with an impact gun, you still have to do all this, ask me how I know.
Darkrune is offline   Reply With Quote
Old 06-16-2017, 09:13 PM   #20
perryair
junior mafia
Drives: ‘20 sti limited
for whatever its worth, i have the prokits on my car and stock everything else and the rear camber is fairly noticeable (and unfixable without new lca's). if i went to the drop of the sportlines, i would likely feel obligated to get lca's to fix that and would therefore spend at least three or four hundred extra dollars doing so.
You get about a solid inch of drop, and it makes it look natural. if you LOVE the super slammed look you'll need to go more but the prokits ride about as harsh as you'd want out of a street car with stock dampers as it is.
20 sti limited | 17 bmw m240i | 16 scion im |15 brz limited {prokit, 17x8 +35 rpf1, bfg comp 2 a/s, stg 2, jdl uel, voodoo knob} | 05 honda civic | 06 scion tc | 95 mustang gt | 89 chevy s-10 cameo
perryair is offline   Reply With Quote
Old 06-18-2017, 11:42 AM   #21
alaskanthundercat
alaskanthundercat's Avatar
Drives: 2017 Subaru BRZ
Thanks, this is what I was worried about - the rear camber. Just gonna keep her at stock height for now until I can afford everything to do it right.
alaskanthundercat is offline   Reply With Quote
Old 06-18-2017, 07:53 PM   #22
Darkrune
Darkrune's Avatar
Drives: 2017 86
He said an inch is fine. I agree.
Sent from my SM-G935V using Tapatalk
Old 06-19-2017, 10:38 AM   #23
Assassin4Hire13
Drives: 2014 BRZ Premium
I put the prokits on my 14 BRZ and really liked how they sat. They settled somewhere between 3/4" and 1" on stock dampers. There's a small bit of rear camber (I don't have any camber adjustment). I also never got the car aligned afterwards (I know I should've buy yolo I guess). Ride is pretty good. Bit harsher than stock but feel and turn in is amazing.
Only problem is that towards the end of your damper's life the ride gets really bouncy.
Assassin4Hire13 is offline   Reply With Quote
Old 06-23-2017, 07:51 PM   #24
-Willis-86touge
Drives: Stock
Got sportlines on mine. Rides just fine until you hit a harsh road the it stiffens up. But not unmanageable. Just feels like a race car. O and I decided to put bigger tires on. I run a 245/40 -18 on a 18x8.5 +35et and no rubbing after I got an alignment. Right now I use just camber bolts and got 1.5 neg camber up front nothing done to the back but showed 2.3 neg in rear hope this helps
-Willis-86touge is offline   Reply With Quote
WTB: Eibach Sportline Lowering Springs crsmlr Canada Classifieds 1 02-27-2016 09:30 PM
WTB: Eibach Sportline lowering springs RicanBRZ Want-To-Buy Requests 1 09-11-2014 11:33 PM
Eibach Sportline Lowering Springs ebhopal Brakes, Suspension, Chassis 6 10-22-2013 05:00 PM
FS: Eibach Sportline Lowering Springs ebhopal Audio/Visual, Electronics, Infotainment, NAV 0 09-24-2013 10:45 PM
Eibach sportline lowering springs.. frsguy707 Brakes, Suspension, Chassis 24 12-14-2012 01:01 PM
