Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
06-11-2017, 04:25 PM | #15 | |
- Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Vten (06-11-2017) |
02-21-2018, 02:43 PM | #16 |
Drives: 2015 Scion FR-S 1968 Camaro BB402
Reviving this thread.
I had the same issue on my 2” tops, figured it out: The spherical bearing that sits stationary in the shock top is two pieces, the spherical ball joint that the shock shaft mounts into and the base on which the joint travels radially. I found (on mine) when I took them apart that if I wiggled the ball joint up and down within its base it was able to move AXIALLY. A horrible design flaw, I should say. Spherical bearings are able to withstand tremendous radial load BUT NOT AXIAL, causing the bearing to wear prematurely. I want to try replacing this bearing, but it is a .0005” press fit so I’m afraid of damaging the actual shock top when trying to get the bad bearing out. Part is supplied by FK Bearings, number FKS10T. Hope this helps!! Sent from my iPhone using Tapatalk |
Similar Threads | ||||
WTB 1" rear raceseng tophats | gallucci86 | Want-To-Buy Requests | 1 | 02-13-2017 12:45 PM |
RCE tarmac 2s for sale with Hvt camber plates and raceseng rear shock top hats | enjoi23 | Brakes, Suspension, Chassis | 5 | 01-02-2017 08:33 PM |
Raceseng 2" rear top plate | puma | Brakes, Suspension, Chassis | 8 | 11-02-2016 02:01 PM |
RCE Tarmac2, Raceseng Cascam, SPL Control Arms, Sway -> SoCal | RawrSoft | Brakes, Suspension, Chassis | 6 | 06-09-2016 09:47 PM |
FS: Robispec rear top hats, OEM front top hats, Scion wheel caps, OEM coin holder | MyRx | Brakes, Suspension, Chassis | 5 | 10-12-2014 02:14 PM |
