| Member's Car Journals Car journals by our members. |
#15 |
Drives: 86 & CX-5
Konig Hypergrams
Just a quick update:
Two 17x9 Konig Hypergrams arrived. Will probably order the other two next week, then get some tire on them!
#16 |
Drives: 86 & CX-5
Testing Fitting the Konig Hypergrams
Thought I would do a test fitting to see what the matte grey Hypergrams looked like on my 86. I think for a little bit of color to brake the grey's I am going to go with blue or some other color lug nut (maybe but not 100% decided on that yet).
Ordered the other two wheels and they should be in next week. Size: 17x9 ![]() PS. Funny how my sons skateboard is the perfect height |
| The Following User Says Thank You to ett808 For This Useful Post: | ERA (05-03-2018) |
#17 |
StreetKart
Drives: 2014 Scion FR-S Monogram
Man, I wish you were in SC or GA... I need to test fit one of those to see if they clear my Caddy brakes :/
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
#18 |
Drives: 86 & CX-5
#19 |
Drives: 86 & CX-5
Tires...
Tires just came in! Hope to get them mounted up this week, then i'll put some pixs up on the Hypergrams.
#20 |
Drives: 86 & CX-5
Tight Fit
![]() Falken Azenis RT615K+ 255/40Rx17 ![]() 2 Wheels in the trunk 4 Tires in the back seat 2 Wheels in the passenger area If it wasn't for needing to get the tire pressure sensors out of my stock wheels, I would have just taking my Mazda CX-5! |
#21 |
Drives: 86 & CX-5
Hub Centric Rings
Had to pick up some hubcentric spacers and new lug nuts before I could change out my wheels and tires.
I guess I wasn't thinking of didn't do enough research but the dudes at the shop said i needed new lugs and hub centric spacers before they could continue. I was in a rush so I just said "ok", instead of having them take the sensors out of my stock wheels and throwing in some regular valve stems, and then mount my new wheels and tires. Then I could have just taken everything home and waited for these parts to arrive. I didn't think about that until I was just about home....(Silly me...) No worries though...It'll get done!! ![]() ![]() ![]() ![]()
#22 |
Drives: 86 & CX-5
Mounted
![]() Right out of the shop less the center caps. Wanted to get the pixs uploaded as fast as possible. I'll wash it and get some better ones later. 17x9 Konig Hypergrams with Falken Azenis rt615k+ 255/40 all the way around. ![]() Didn't have much time to drive it yet, but first impressions. Noise: Not bad at all (so far) Grip: YES!!
#23 |
Drives: 2015 BRZ
how much are you lowered? Any rubbing issues in front?
#24 |
Drives: 86 & CX-5
On stock wheels and tires I was about 2.5 fingers. So far it hasn't rubbed with the new setup, but I have barely driven it at all. I don't anticipate it will rub though. I am on Tein coilovers btw. I'll follow up if it does rub.
| The Following User Says Thank You to ett808 For This Useful Post: | Vital (04-19-2018) |
#25 |
Drives: 86 & CX-5
ET86 Phase 1 Updates
![]() Phase 1 almost done. ![]() Phase 1 almost done. ![]() Next upgrades to complete Phase 1: - Front Sway Bar (Maybe rear too) - Front Strut Tower Bar (Just Cause) - Rear Lower Control Arms |
#26 |
Drives: 2015 BRZ Limited
Good choice on the tires!
| The Following User Says Thank You to JeremyR For This Useful Post: | ett808 (04-20-2018) |
#27 | |
Proud of BOXER
Drives: Subaru Boxer
I love their tread pattern! I want to try them as my next tire!
| The Following User Says Thank You to Clipdat For This Useful Post: | JeremyR (04-20-2018) |
#28 |
I love mine man..can't stay good enough things about them.
Only downside is they slip in the cold.. I was on hwy 9 in like 30-35 F weather at night and they were not warmed up enough so i got slippage. Also, not so good around corners on hwy 9 in the wet either..but i try to avoid driving my car when it rains when possible so this isnt a big issue for me. the dry grip is great though, debating if i wanna stay with these or give advans a try next
| Kai's 2017 Toyota 86 | 86Kai | Member's Car Journals | 68 | 08-23-2018 10:08 PM |
| Toyota 86 Mud Guards on 2017 BRZ | JSube | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 05-01-2017 11:57 AM |
| 2017 Toyota 86 QUESTIONS | Clee | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 02-08-2017 03:15 PM |
| 2017 toyota 86 AT | BrokenSouls | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 10-18-2016 10:22 AM |
| 2017 Toyota 86 | Driftz | Southwest | 3 | 06-04-2016 03:52 PM |
