Old 06-01-2017, 08:11 PM   #15
oldgunfan
oldgunfan's Avatar
Drives: 2014 BRZ sterling silver
I have a 2014 BRZ and some of these guys will tell you I just went through this. And Andrew at RCE and some of the other guys on the forum talk me into Bilstein B6 and RCE yellows I also have Velox LCA and rear Toe arms. I just put them on Last weekend and I'll tell you it is a great combo. It is stiffer but some how soaks up the bumps at least twice as good as stock and it stay way flatter in the corners. I just got an alignment yesterday soo I haven't driven it too much but so far i'll say it's a bad ass setup
oldgunfan is offline   Reply With Quote
Old 06-05-2017, 10:55 AM   #16
jmark
Drives: '97 NSX-T, '18 Type R
Any updates?
jmark is offline   Reply With Quote
Old 06-05-2017, 12:05 PM   #17
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
What was your reasoning for the rear toe arms with those springs?
Old 06-05-2017, 01:16 PM   #18
wparsons
wparsons's Avatar
Best argument I have for most people is that the aftermarket toe arms (with a lockout washer) won't slip like the stock arms can.
flickr
Old 06-05-2017, 01:44 PM   #19
RichardJ
RichardJ's Avatar
Drives: 15' FRS
Originally Posted by gramicci101 View Post
You'll end up paying to replace the shocks eventually no matter which suspension plan you go with, but it's maybe a once every 5-10 year expense unless you break something, so I wouldn't worry too much about replacement costs at this point.
I would go ahead and assume RCE Yellows are a given (they're really nice), and look at shocks. If you can find a low mileage 2017 set for not very much money, go for it. Try to snag the top mounts with them; they're just as much a part of the suspension as the springs are. If they're approaching the cost of a new set of B6's, just spend the extra and get those instead. I would personally set that line at 2/3 the cost of a set of B6's.
I've been on RCE yellows and OEM 2014 shocks for 50K miles, with no issues. I'm waiting patiently for RCE's upcoming Bilstein coilovers, but that's only for wheel fitting purposes. If I don't go that route I'll get B6's when my struts wear out.
Interesting, I got my RCE yellows installed by a local shop that specializes in this platform and both my rear shocks blew after <5k. To be fair I live in downtown Toronto which has pretty garbage roads with potholes everywhere. Still unsure if I should replace with OEM shocks or save up for a B6..
RichardJ is offline   Reply With Quote
Old 06-05-2017, 02:01 PM   #20
gramicci101
Off Topic
If you go for OEM shocks, look for '17 takeoffs. Other wise go with the B6.
Old 06-05-2017, 02:22 PM   #21
Summerwolf
Panda Trueno
Summerwolf's Avatar
Ahh, I haven't seen toe arms be a common item with a mild drop.
Old 06-05-2017, 03:27 PM   #22
wparsons
wparsons's Avatar
Yeah, they wouldn't be needed to get the alignment in spec.
flickr
Old 06-05-2017, 06:41 PM   #23
oldgunfan
oldgunfan's Avatar
Mostly because the guy I got the LCA's from had the toe arms too. But I'm glad he did, I think the toe would have been off and then I wouldn't have been able to do anything about it.
Old 06-05-2017, 06:43 PM   #24
strat61caster
strat61caster's Avatar
Factory toe links have a wide adjustment range, they likely would have been perfectly fine.
ineedyourdiddly
Old 06-05-2017, 06:51 PM   #25
oldgunfan
oldgunfan's Avatar
Originally Posted by jmark View Post
Any updates?
Been driving it to work. Haven't done anything too crazy with it. I will say I bet the only stock car on the road around here that might out handle it (and he says it may not) is my neighbor's porsche cayman s going down our Mountain.
Old 06-05-2017, 07:52 PM   #26
oldgunfan
oldgunfan's Avatar
I really didn't know the stock one's were adjustable till I took them off. They didn't seem to move very much though but they probably don't need to. You may be right Stat61caster but my alignment guy was very happy to see them.
Old 07-12-2017, 11:03 PM   #27
ermagawd
ermagawd's Avatar
Drives: Crystal White Pearl
@Racecomp Engineering Would you still go B6+RCE Yellow if you already own the 2017 brz? would there be a significant upgrade? the purpose is mainly a daily driver and occasional track (4ish times a year)
ermagawd is offline   Reply With Quote
Old 07-13-2017, 09:34 AM   #28
Darkrune
Darkrune's Avatar
Drives: 2017 86
It is a different experience. The tail becomes much more stable and the turn in is strong and very predictible. I love the square spring rate. I had yellows on my 13 BRZ and now my 17 86.
Darkrune is offline   Reply With Quote
WTB stock rear tophats or complete stock suspension s13kid989 Want-To-Buy Requests 3 10-09-2014 07:11 AM
FS: RCE Yellows on stock struts (complete package) sw20kosh Brakes, Suspension, Chassis 6 07-02-2013 05:02 PM
Spacers with RCE Yellows on Stock Rims/Tires? husker741 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 05-04-2013 04:21 AM
Pic of RCE yellows on stock wheels? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-23-2013 10:10 AM
