Old 05-10-2017, 12:14 PM   #15
humfrz
Here is a variation we called "stump tea".
@Scrappydoo .......try to find a reference for that ......
Place 1 dozen tea bags in a gallon of cold water and place on a stump in a sunny spot. Let brew for several hours. Cool it in the shade. Best tea you will have ever had .....
humfrz
Old 05-10-2017, 12:26 PM   #16
spd
Drives: wrx, brz
fwiw, any type of tire gel or shine will last longer if you clean the tires with something like an All Purpose Cleaner beforehand. If your tires are brown looking, you definitely need to clean them first as that's a sign they're blooming. If you just put tire gel over brown tires it'll only last a few days max.
Lately, I've been partial to Adam's Polishes VRT, it leaves a nice satin/new tire look.
spd is offline   Reply With Quote
The Following User Says Thank You to spd For This Useful Post:
Tcoat (05-10-2017)
Old 05-10-2017, 12:52 PM   #17
Or it is muddy where you drive.
Old 05-11-2017, 12:27 AM   #18
Impureclient
Drives: 2015 FR-S
Or a dog planted a #2 up on it. I'm rolling with one brown tire on my work van right now.
Impureclient is offline   Reply With Quote
The Following User Says Thank You to Impureclient For This Useful Post:
Tcoat (05-11-2017)
Old 05-11-2017, 10:23 PM   #19
BigHugeFatGuy
BigHugeFatGuy's Avatar
Drives: 2016 FRS
Originally Posted by swarb View Post
Why don't you ask the dealer? Or do you think they all use the same toyota branded tire shine?
That's what I was wondering if there's something branded they use across the board.
It's not a dirty tire issue. Car is new, and dealer tire stuff is lasting. I've washed it a few times and it just beads off instantly. Leaves nasty black stuff on the mf towels when I clean the wheels tho, so it's pretty thick. You said the key words of satin/new, and that's the look I want to keep, so I'll have to check out the VRT. Thanks.
BigHugeFatGuy is offline   Reply With Quote
Old 05-12-2017, 06:32 AM   #20
I doubt they have one branded one they use everywhere. Any of the higher quality ones should do you. Keep in mind tat if it is beading water then it is leaving a coating on the tires. You may want to scrub them down with a heavy cleaner every now and then so that coating doesn't just keep building up until it looks horrid.
That isn't likely the tire treatment that comes off on your wheel, just brake dust.
Old 05-13-2017, 02:17 AM   #21
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Originally Posted by radroach View Post
I recommend 303 aerospace protectant. No shine, just nice black tires. Lasts a good while too per application.
the wet look is too..flashy
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 05-24-2017, 11:51 PM   #22
Borchert97
Borchert97's Avatar
Drives: 2017 Toyota 86
I work at a Subaru dealership prepping cars for delivery and we use this bottle of purple liquid called tire dressing or tire shine, I have no idea what brand though, we get it through our dealer's supplier, although a lot of our other supplies are Car Brite brand so perhaps this one is it, looks the same:
Borchert97 is offline   Reply With Quote
The Following User Says Thank You to Borchert97 For This Useful Post:
Tcoat (05-31-2017)
Old 05-31-2017, 08:43 PM   #23
NLS8520
Drives: N/A
When it comes to tire care, you really want a gel something that will protect the rubber and provide a nice finished look. To achieve: First and foremost clean and scrub the tires thoroughly with a tuff shine tire brush and your favorite automotive APC, this cleans and preps the surface for bonding of the gel. The store bought shit generally slings and its just silicone junk. I recommend any of the following : Optimum Tire Gel, Adams super VRT, Ammo Mud, Gyeon Tire. Apply with an Adams waffle tire gel applicator. They should all last at least 1 month and none sling if applied correctly. If you want a longer lasting solution there are tire coatings. Tuff Shine makes one that I have used many times and really like it, leaves a nice look and lasts months, the only problem is that it takes a long time to get the tire nice and clean before application.
NLS8520 is offline   Reply With Quote
Old 06-01-2017, 10:52 AM   #24
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
"blooming"....never knew that's what it's called...
venturaII is offline   Reply With Quote
Old 06-02-2017, 09:29 AM   #25
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I don't have a good answer to your question, but I have an alternative.
I use sonax on the wheels and tires, and scrub really vigorously on the tire. They generally look nice and black when I'm done, but it doesn't last that long, (they get dirty quick.)
I follow up with Meguiars endurance, I put on a medium thickness coat, give it a few seconds, and wipe off with a microfiber. They look VERY black, not very shiny. Perfect for me.
https://www.amazon.com/Sonax-230200-...keywords=sonax
https://www.amazon.com/Meguiars-G751.../dp/B0009IQXJ0
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 06-02-2017, 12:18 PM   #26
venturaII
venturaII's Avatar
Just to throw another combo in the ring, I use Bleche-Wite to clean the wheels and tires, and then a quick wipe of Vinylex with a sponge, and wiped dry with a clean towel. Very black, and no shine.
Old 06-02-2017, 02:00 PM   #27
JazzleSAURUS
I have a few friends with whitewall laden rides and they all use the Bleche-Wite. They have great results. I imagine it would work great with the tire letters, but that's not my thing so I haven't tried it.
Old 06-02-2017, 02:23 PM   #28
venturaII
venturaII's Avatar
Yeah, it's the bomb on tires with white lettering or whitewalls, but it also does a great job of cleaning just straight-up black rubber, and of course, wheels. The Vinylex leaves a nice, low-key finish.
Hey what is this? Black Box, Rear tire compartment. Xdragonxb0i Scion FR-S / Toyota 86 GT86 General Forum 13 10-23-2021 09:14 PM
Tire deal for black friday bakerr6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 11-29-2016 04:38 AM
CruiseControl's Ultramarine FR-S - Perrin Tips, Shark Fin, JDM Stuff, Other Stuff CruiseControl Member's Car Journals 4 07-01-2014 05:53 PM
Anyone with black/aluminum acrylic stuff from DD? Vmax911 Cosmetic Modification (Interior/Exterior/Lighting) 5 11-05-2013 08:26 PM
