Old 05-01-2017, 08:31 PM   #15
BRZSteve
BRZSteve's Avatar
Drives: WRB BRZ
Originally Posted by mav1178 View Post
Have you considered contacting Tein USA about this?
If the shock body is bottoming out in the lower bracket, they made a design change in production that has obviously impacted the advertised specs.
My Ohlins from 2013 were a similar situation, I suspect they used parts from another platform to reduce some manufacturing costs.
-alex
I just contacting them over the phone and they said it was my preload. Apparently this was a common problem. They gave me a link on how I should fix this so ill post it in here if anybody needs. Hopefully this works
http://teinusa-blog.com/applying-suspension-preload/
WRB BRZ
BRZSteve is offline   Reply With Quote
Old 05-08-2017, 07:26 AM   #16
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
You have tons of threads showing. If you want lower you want to the lower cup to move closer to the springs
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
D_Thissen (05-08-2017)
Old 05-08-2017, 10:48 AM   #17
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
x2
you put more pre-load not height. i was thinking about samething when i saw many thread showing
Old 05-08-2017, 10:58 AM   #18
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Just because there are threads showing doesnt mean that there is anymore adjustment. If the shock body is bottomed out in the cup, that is the lowest it'll go. We have the same coilovers on our car:
This is max adjustment for the rear on our set.
OP, that's all we got out of our car too (same wheels too), but we had a taller sidewall tire, which helped a bit with the gap. We never bothered with adding more preload, as I dont think it would have had the effect we wanted. Yours honestly looks a little bit higher, but it could just be the different tires. It's entirely possible that the shock bodies are longer than they should be, but obviously I'm not positive. But it is a reasonable explanation for why it would be higher than others when maxed out.
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to GrimmSpeed For This Useful Post:
BRZSteve (05-09-2017), zc06_kisstherain (05-08-2017)
Old 05-08-2017, 12:50 PM   #19
SuperTom
SuperTom's Avatar
Chase
Engineering
I see what you mean. If the shock body is too long for those then no more will fit into the bottom cup.
Old 05-09-2017, 04:42 PM   #20
BRZSteve
BRZSteve's Avatar
Drives: WRB BRZ
Chase
Engineering
Thanks for the detailed response, this makes sense now. And yeah, the tire definitely has something to do with it, these are fairly thin sidewalls. The only thing that is confusing is that the passenger side is at least a 1/2 inch lower then the drivers side, which makes me think I did something wrong.
WRB BRZ
Old 05-09-2017, 05:18 PM   #21
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
Keep in mind the springs will end up settling a tad. Mine looked similar to yours when I first installed them and now I have in between a 1 and 2 finger gap in the rear
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
The Following User Says Thank You to BFIFE22 For This Useful Post:
Tein Flex A DeaconRoc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 138 04-12-2018 05:23 AM
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 03:44 PM
Help wanted: Tein Street Flex for $950 or Flex Z or $820? chezzy79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-01-2015 09:33 PM
Tein Flex Z Bigmaxy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2015 03:22 AM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
