Old 05-13-2017, 01:33 PM   #15
phrosty
Originally Posted by Frenatardi View Post
Well yesterday I finally filled with E85, after some miles I pulled over and reflashed. After driving gently more than 35 miles I did some pulls and I saw FLKC at -1.59! It drops negative everytime I'm avove 6700 rpms. I should be worried about that?
How much did you drain the tank before adding E85? Your E% may not be high enough to handle the added timing.
You should also let your high-MAFv LTFT settle before doing any pulls. Doing slow 20% throttle climbs to 5000rpm will help expedite this -- plug in your OFT, if your fuel system goes open loop (4) then you're giving it too much throttle.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
Frenatardi (05-23-2017)
Old 05-13-2017, 05:37 PM   #16
Frenatardi
Frenatardi's Avatar
Drives: Subaru BRZ 2016
When the low fuel light came on I still drove for 20 minutes, it was not totally empty but almost.
Yes, I did 3 slow light steady throttle from 2000 to 6000 before the WOT pulls. But yeah, maybe I should had let the ecu learn the new tune a few miles more.
How much negative FLKC is acceptable?
Thanks for your reply
Frenatardi is offline   Reply With Quote
Old 05-13-2017, 07:42 PM   #17
steve99
Preferavly no negitive flkc or fbkc knock the occasional spike to less than -1 is acceptavle, but if you get consistent knock in an area then best to mod tune slightly. Knock can ve due to several reasons but too much timing or too lean ar main causes
Just post up the link to your datalog in datazap make sure it set to public then we can look at other parameters like ltft and iam and afr to see whats going on
The level of knock you have is acceptable but at get worse with continous hard driving
Old 05-13-2017, 07:54 PM   #18
Frenatardi
Frenatardi's Avatar
Ok then, occasionaly less than -1... it seems I'm way off that. I can't wait to go for a drive again and see what happens. Thanks for your help, here is the datalog link.
http://www.datazap.me/u/frenatardi/e...r?log=0&data=1
Old 05-13-2017, 11:55 PM   #19
steve99
Looks ok fuel trims are good looks like your e85 has arround the 80% or so e content if thats first tank. Its running pretty good afr log commamded afr nex time maybe leve out lateral g.
Keep an eye on the knock their was one bit their -1.5 if that continues id take a little out of the timing map in that are. But do a couple more logs and see if its hapens again
Old 05-23-2017, 03:16 PM   #20
Frenatardi
Frenatardi's Avatar
http://www.datazap.me/u/frenatardi/h...5?log=0&data=1
Flkc keep dropping every time I drive above 6700 rpm. However when cruising and driving normally stays at 0. IAM consistent at 1 all the time.
Here it comes my last question. Should I pay somenone to fix that with custom tunning (assuming I don't know how to do it myself) or maybe I should stop worrying?
Thanks everyone that replied my post. I wish someday I could have enough knowledge to help you guys out.
Old 05-24-2017, 05:07 AM   #21
steve99
Just needs a litt!e ignition timing pulled at high rpm and maybe a little maf scaling to coresct afr
European Forum List Koj EUROPE 14 03-28-2019 07:52 AM
New OFT Tune optimized for USDM E85 EL with Enhanced Performance vs OTS/Wayno's! BRZ Fanboi Software Tuning 53 09-13-2015 08:11 PM
TAS300 on European GT86 Pacific Electronics | Audio | NAV | Infotainment 0 11-10-2012 06:35 AM
GT86 European headlights ? rikdrt1 Cosmetic Modification (Interior/Exterior/Lighting) 7 07-18-2012 05:32 AM
European delivery date ? Sylvain44 BRZ First-Gen (2012+) — General Topics 6 06-04-2012 08:27 AM
