Old 04-17-2017, 01:58 PM   #15
Originally Posted by Infinity View Post
People get so weird on here about intakes. They have no problem telling you to spend $80 on a new filter, but $200-300 for an intake? You must be some kind of incompetent retard that likes lighting money on fire. Compared to some of the other "worthless" mods people do, it is actually on the cheap side. And, depending on the one you get, it may clean up the engine bay.
I believe the Grimmspeed is/was considered the "best". There was a big development thread going on here for a while. If you have $330 burning a hole in your pocket go for this.
If not, I would go for something like the Perrin Inlet Hose or Mishimoto Induction Hose paired with a drop in filter from Perrin or K&N. Should run about $150-ish.
Don't think anybody was calling anybody "incompetent" nor "retard". If you feel that dressing up the engine bay is worth $300+ then yes it is a good mod. If you are looking for performance then it is not a great investment when looking at the gains per dollar. Much of the hype about intakes is driven from the crowd that did the improvements to cars that actually needed it or the fact that it is indeed something that gives great visual impact so it MUST improve performance.
He has a 17 which already has a larger hose and filter area. Any gains that the 13-16s would get from such are greatly reduced and again the benefits are only cosmetic in nature. Actually don't think there are many drop ins out there for the 17s yet.
Cole (04-17-2017)
Old 04-17-2017, 02:02 PM   #16
Cole
Not a troll
Cole's Avatar
You clearly don't understand what "value" means. If you get something for 1/4 of the price, with half (and in many cases, it's closer to 3/4) the gains of something else, that's a value. As far as cleaning up the bay, a $2 rubber plug and a hose clamp, coupled with a 12v plug will clean up the sound tube. Also, dunno where you're getting $80 for a filter, most are under $60, and even more are under $50.
Old 04-17-2017, 02:04 PM   #17
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
....Actually don't think there are many drop ins out there for the 17s yet.
This is the only one as far as I know:
http://www.frsport.com/Blitz-59624-S...p_1475641.html
The 2017 MT is the only one with a different sized filter. The 2017 Automatic uses the same filter as the previous years.
justinco is offline   Reply With Quote
Old 04-17-2017, 02:09 PM   #18
reynierpm
Drives: Toyota 86 2017 Black
Just to be sure I'm on the same page as you, are you talking about this parts:
I think the 2nd and 3rd are the same one is cheaper maybe to the clearance or the color.
Thanks,
reynierpm is offline   Reply With Quote
Old 04-17-2017, 02:09 PM   #19
Ah yes good point on the MT and AT. I keep forgetting that.
Old 04-17-2017, 02:44 PM   #20
Infinity
Drives: 2016 Scion FR-S
I had the Perrin intake and inlet tube on my FRS. Sounds nice and cleans up the engine bay. But, you have to remove the bumper to install it and doubtful it actually makes any extra power.
I had the Grimmspeed intake on my 2017 BRZ. Again, sounds nice, doesn't change engine bay much except removes sound tube. Don't have to remove the bumper but again power gains are not noticeable.
Current state: I just removed the Grimmspeed intake and put the stock airbox back in, with a Perrin inlet tube and drop-in filter. Works great, inexpensive, and so far this is my favorite combo (stock box, drop-in filter, Perrin inlet tube).
Why did you remove the Grimmspeed and go back to the Perrin inlet tube + drop in filter?
Infinity is offline   Reply With Quote
Old 04-17-2017, 02:48 PM   #21
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
"Works great, inexpensive, and so far this is my favorite combo (stock box, drop-in filter, Perrin inlet tube)."
PetrolioBenzina is offline   Reply With Quote
The Following 2 Users Say Thank You to PetrolioBenzina For This Useful Post:
Cole (04-17-2017), justinco (04-17-2017)
Old 04-17-2017, 02:51 PM   #22
Infinity
Thanks,
Yes, those are the parts I am talking about. There are many options here:
http://www.ft86speedfactory.com/inta...-tubes-82.html
http://www.ft86speedfactory.com/inta...ilters-88.html
It seems these parts might not fit on a 2017, though.
Old 04-17-2017, 02:52 PM   #23
PetrolioBenzina
Drives: 17 86
They could have at least used a decent looking example for the photo. I'd be annoyed if I opened the box and saw that.
Old 04-17-2017, 02:55 PM   #24
PetrolioBenzina
Drives: 17 86
OP, why are you still considering an intake? As others have said, your 17 has more improvements to the intake system than any aftermarket intake (so far) has, and with only one (TRD may have an oiled filter) filter so far, save your money.
A cold-air intake is a waste of money without FI anyway. Toss this on the do later pile.
The Following User Says Thank You to PetrolioBenzina For This Useful Post:
reynierpm (04-17-2017)
Old 04-17-2017, 02:58 PM   #25
reynierpm
Ok, then I won't change and will save money as many of yours suggested (which I need for wells and tires )
Old 04-17-2017, 03:00 PM   #26
PetrolioBenzina
Drives: 17 86
Thanks,
Those are listed for the 13-16 FR-S/BRZ. You have a 17 86.
Old 04-17-2017, 03:01 PM   #27
PetrolioBenzina
Drives: 17 86
Yeah, money much better spent, at least for now.
Old 04-17-2017, 03:18 PM   #28
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
And a spelling tutor?
Scrappydoo is offline   Reply With Quote
Time for my first oil change Deagle50 Issues | Warranty | Recalls / TSB 5 05-13-2015 05:20 PM
It has been fun, but time for a change! jskurucz Other Vehicles & General Automotive Discussions 49 04-28-2014 05:56 PM
It's time for me to change things up a bit... Drive Scion FR-S / Toyota 86 GT86 General Forum 23 02-03-2014 10:37 AM
Time for the second oil change yet? ProTekk Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 11-16-2012 03:13 PM
Waiting a year for the 86. What would you recommend for the mean time? Avatar_Ko Other Vehicles & General Automotive Discussions 23 02-05-2012 10:52 PM
