Old 03-31-2017, 08:45 AM   #15
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I've been using Grimmspeed gaskets for a few years on my Forester XT, and now my BRZ.
Very happy with them, a few of them have been in use the entire life of the current motor with no issue, and will be replaced with fresh grimmspeed gaskets when I do the next motor.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 03-31-2017, 10:46 AM   #16
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Originally Posted by Gabzor View Post
Had no problem on the header, just OP/FP.. @GRimspeed do you guys sell any 2.55 gaskets for the perrin? loved the quality of your gaskets vs that one
Have you tried loosening the head to header, header to OP, OP to FP, FP to CB, and then gradually tightening them all back down in small increments? More often than not that will work, and if it doesn't I really wouldnt be surprised if you have a warped flange at your OP/FP connection.
Nah, I dont think that we do. I've never touched the Perrin part you're talking about, so I have no idea. Our hybrid 2.25/2.5in gasket is designed to fit the subaru specific bolt pattern, as most parts do. The ID of our gasket is 2.48in. So assuming the perrin part has an ID of 2.55in, our gasket would sit inside that ID by .035in, which will seal the fire ring. If you're alignment is off though, and the edge of the fire ring were to completely overlap the ID of the flange it will leak.
So there is a couple things to try and to look out for. But I bet you'll get it.
Yeah seriously they are the only gaskets I've ever used in my life that I've been able to reuse several times over. And when we do R&D here we'll have a car apart and put back together so many times (way more than what any average person would do), and I can get away with reusing them so many times it's ridiculous. Plus, being stainless steel greatly increases their longevity.
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
EXHAUST Gasket Exrald Northern California 1 03-25-2017 11:44 PM
Overpipe gasket exhaust leak THEWAKLER Engine, Exhaust, Transmission 19 11-29-2015 01:38 AM
Exhaust Gasket: OEM or Aftermarket? Wilcats Engine, Exhaust, Transmission 3 05-21-2015 08:22 PM
60mm Exhaust gasket denkigrve Northern California 2 07-02-2013 08:53 PM
BRZ Donut Gasket same part as WRX STi Gasket? Zadkiel Engine, Exhaust, Transmission 0 10-06-2012 07:22 AM
