#15 |
A.K.A. Starlord
Drives: 2015 Series.Blue
This was AFTER I got done hooning around on local roads for 30 minutes. Turns out our radiators don't need air to work, lol.
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
#16 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
If it were physically possible to have snow covering your grille on a 110° day, I'd say that's about the only time you'd be concerned about your grille being obstructed by snow. If it's cold enough to snow, it's cold enough to not worry about your car overheating unless you're bouncing off the Rev limiter for 5 minutes...at which point you'll have many other problems.
Old school cars used to actually close the grille slats in cold weather to keep cold air out. Humfrz probably remembers that.
-O/D
2016 FR-S, Hot Lava |
#17 |
Drives: 15 BRZ LTD, 05 FXT
The option I went with was the black housing, glass lens outback fogs, with Hella H11 bulbs in yellow, and a PSX24W to H11 adapter. I'm happy with my solution.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
#18 |
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
I was mostly being facetious, but there ya go.
I did a little hooning last night too. Couldn't resist.
@bpennerz
#19 | |
A.K.A. Starlord
...wait, no, that's EXACTLY what I did :P
| The Following User Says Thank You to Stang70Fastback For This Useful Post: | SLVRSRFR (03-14-2017) |
#20 | |
One of the glass fog light lenses on my 944 that I used to have about 10 years ago cracked after a huge rock was kicked up by an 18-wheeler I was following. I watched it bounce, bounce...and then heard a sickening "ting" sound. Got home to see the glass lens cracked right the way through.
@bpennerz
#21 | |
Sittin' Sideways
Can't wait to allegedly hoon around the neighborhood later...
-O/D
| The Following User Says Thank You to Overdrive For This Useful Post: | Stang70Fastback (03-14-2017) |
#22 | |
I generally prefer glass lenses as they are much clearer, don't pit as fast, and can usually be replaced. For $35/side, I'll just buy another housing and swap it out and enjoy being able to run higher wattage.
| WTB fog light bulbs | Jajanken86 | Want-To-Buy Requests | 0 | 11-21-2016 08:31 PM |
| led license plate bulbs keep burning out | DanBrz91 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 04-28-2016 06:55 PM |
| 10 Series Fog light bulbs. | 0351USMC | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 03-10-2015 08:36 AM |
| Light Bulbs | FRSure | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 02-05-2014 11:50 PM |
| LED fog light bulbs | pghfan19 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 12-10-2013 12:38 AM |
