Old 03-07-2017, 07:06 PM   #15
radroach
Drives: car
The only difference I noticed from going from factory fill to Motul was a different feel. On stock fluid, the gear changes would feel and sound different. With motul the gears for me would glide more easily and have much less of a chunky sound. Even though I missed the way the stock fluid felt when fresh, the motul has allowed my shifts to be much faster. The slickness just allows the gears to be thrown easier.
Cold fluid has always been a problem. If its below 30 degrees then I usually have a warmup driving around slowly first before normal driving so that I get all the fluids circulated.
Old 03-08-2017, 10:53 AM   #16
DarkSunrise
DarkSunrise's Avatar
The only difference I noticed switching to Motul is that shifts felt more mechanical or had more feedback. I wonder if Motul is slightly less viscous than stock fluid at certain temps (within the tolerance range of the 75w90 spec obviously). In any event, I haven't had any problems using Motul and will continue to use it.
2022 BRZ Build
2013 FR-S Build
Old 03-08-2017, 11:48 AM   #17
Edibrac
Edibrac's Avatar
Drives: 15 Series.Blue
I had the original oil in for 20k miles and then switched to AMS oil. The shifts were better, like everyone says about going away from the factory oil. Cold shifts were not a problem. At 40k I put Motul 300 in and have driven 10k miles since. Cold shifts are horrible. It was fine in the summer but once winter hit, 2nd, 3rd, and 5th were always difficult to get into when cold. So I am switching back. I believe it is fine for warm climates but not cold ones.
Edibrac is offline   Reply With Quote
Old 03-08-2017, 01:47 PM   #18
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Had mine change, really no difference. You can pour liquid gold in the car but cold shifts are going to be rough regardless.
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
Old 03-09-2017, 03:30 AM   #19
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Like everybody said...it suck during cold weather..
I have problem everyday when shifting into R, I have to warm it up by shifting gear 1 to 6 before I can reverse...
After it get warms up, its feels smoother especially downshift into 2nd gear.
FR-Sky is offline   Reply With Quote
worse about forums fatoni Off-Topic Lounge [WARNING: NO POLITICS] 33 04-05-2016 07:07 PM
motul 300 vs motul 300ls about to buy some need help. NickFRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 03-24-2016 11:51 PM
Tried to prevent rust, may have made it worse... KPR10 Issues | Warranty | Recalls / TSB 36 04-24-2015 04:04 PM
What's the worse mod you've seen so far? frosty86 Scion FR-S / Toyota 86 GT86 General Forum 43 10-16-2012 11:27 AM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 06:09 PM
