Old 03-31-2017, 11:13 AM   #15
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
Here is a couple of shots of my setup
Sent from my E6883 using Tapatalk
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 03-31-2017, 03:05 PM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm, how did you concealed stock brake light's mounting holes?
Old 03-31-2017, 03:38 PM   #17
MemphisR
Memphis
MemphisR's Avatar
I used craft foam to fill the holes, then wrapped the whole shelf in alcantara.
Old 03-31-2017, 03:49 PM   #18
imnotsureaboutbrz
Drives: between cars...
F'ing CLEAN! are you using the intec 3rd brake light?
imnotsureaboutbrz is offline   Reply With Quote
Old 03-31-2017, 04:41 PM   #19
MemphisR
Memphis
MemphisR's Avatar
No. It's one I made myself.
Old 03-31-2017, 08:39 PM   #20
PNW FRS
PNW FRS's Avatar
For comparison...
Each to his/her own... I went with a single of the Mustang light... seems to be sufficient; no one has rear-ended me (crossing fingers!)
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 03-31-2017, 10:30 PM   #21
imnotsureaboutbrz
Is the mustang light cheaper than the intec version that's plug and play?
http://www.ft86speedfactory.com/inte...l#.WN8Qmjw777o
Old 03-31-2017, 10:42 PM   #22
MemphisR
Memphis
MemphisR's Avatar
Yes... A lot
Old 03-31-2017, 11:29 PM   #23
PNW FRS
PNW FRS's Avatar
Yes... "Mustang" light is about $55. Keep in mind that how the "housing" comes in contact with the rear window is way different than the Intec light. The Mustang light housing uses 3m tape on all four edges to mount to the glass. Install takes a bit of care...a steady hand... and where the tape sticks to the glass WILL be visible from outside. That's why I added the HIC visor -- to "shade" the housing and keep it less visible.
And... if you are planning on tinting the rear window... do it first.
2013 Asphalt / MT
Olympia, Washington
Old 04-01-2017, 01:52 AM   #24
Leonardo
Country Boy 4 Life
Leonardo's Avatar
http://www.ft86club.com/forums/showt...=113557&page=2
I LIKE TIRES!
Old 08-03-2017, 06:45 PM   #25
BabaYaga
BabaYaga's Avatar
Drives: FRawSome Hot Lava
Alcantara
Where did you buy the alcantara?
BabaYaga is offline   Reply With Quote
Old 08-03-2017, 07:35 PM   #26
MemphisR
Memphis
MemphisR's Avatar
Ebay
Old 05-31-2018, 03:51 PM   #27
sythe53
Drives: 2013 Release Series 10
Please tell me how to mount this permanently. I have the intec high mount, and have tried gorilla tape, and a fresh strip of 3m to no avail.
Thanks In Advance
sythe53 is offline   Reply With Quote
Old 05-31-2018, 06:42 PM   #28
86raus
86raus's Avatar
Drives: 2017 blue toyota 76
Use epoxy glue i had the same issue used a few different tapes but it kept falling off so I just used a 2 resin glue gun haha it is permanent now.
Sent from my SM-G955F using Tapatalk
86raus is offline   Reply With Quote
Third brake light...(top mount) Slide Cosmetic Modification (Interior/Exterior/Lighting) 103 02-22-2017 02:47 PM
Intec High Mount Brake + Rear Dash Cam SmartedPanda Electronics | Audio | NAV | Infotainment 7 02-11-2017 03:44 PM
Top mount 3rd brake light Jonesy86 Northwest 1 06-12-2015 02:41 AM
