| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
For the 500th time the paint isn't too "soft" it is too HARD!
We actually want softer paint. And yes I know you were being sarcastic.
| The Following User Says Thank You to Tcoat For This Useful Post: | new2subaru (11-04-2017) |
#17 | |
Drives: '15 BRZ RA
http://www.agc-automotive.com/en/our...eight-glazing/ It says clearly that they are working with original equipment manufacturers. |
#18 |
Drives: 2017 BRZ
How does the clarity of the replacement windshields compare to original? I've been annoyed by the fine scratches I've had since day 1.
#19 | |
Doesn't matter if they make it thinner it still has to meet all the requirements. The ability to withstand impacts is one of them.
#20 |
Drives: '15 BRZ RA
I think you are confusing this with the requirement a cracked windshield to not fall apart. This can be done by placing a thin sheet of clear plastic that holds the two tempered glass layers together. This layer prevents you also from getting a lap full of glass when a rock hits your windshield. As far this requirement is satisfied, I don't think they have other regulations. I could be wrong, but I would expect to point some source of your statement.
#21 | |
There are no less than 6 impact tests that MUST be passed. They can make it as thin and light as they want it still has to pass the tests to be approved. I am fully aware of all the requirements and not confused about anything. This is the sort of shit I have done for a living for the last 30 years. This is not some theory that I made up it is a legal requirement. Basing your theory on the fact that a couple of guys got chips early in their ownership is ridiculous. http://www.interautoglass.org/conten...NSI_Z26_11.pdf
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (11-12-2017) |
#22 | |
Drives: '15 BRZ RA
You are looking pissed off. You could just provide the document and it would be fine with me. At least we know now that some car glass companies have the option to make a windshield as thin and light as possible with the restriction to pass some tests. Last edited by nikitopo; 11-04-2017 at 06:47 PM. |
#23 | |
Weight Weenie
Drives: 15 FR-S
Do you think they would have the same safety requirements? |
#24 |
Drives: 2017 BRZ
Windshield standards and low quality windshields are not mutually exclusive.
#25 | |
Drives: 2018 Miata RF, 2017 Golf R
| The Following User Says Thank You to unhappymeal For This Useful Post: | Tcoat (11-10-2017) |
#26 |
The lamination is between the sections of glass so would not prevent chipping anyway.
#27 | ||
Drives: 2015 Series.Blue
At least we don't have exploding sunroofs like some other cars are having issues with... |
| The Following User Says Thank You to Poodles For This Useful Post: | Tcoat (11-11-2017) |
#28 |
In 2011 the governments around the world agreed to reduce the amount of VOCs (volatile organic compounds) in paint. Heavy restrictions were placed on what chemicals could be used by the automotive industry.
Unfortunately many of those chemicals were what made the paint strong yet resilient. The application processes in use were not suitable for the new chemistry and we ended up with hard, brittle, coatings that chip easily especially with small impact surface areas. To visualize what happened just paint a pool ball and a tennis ball and drop each. The paint on the pool ball will chip since it can not flex. The tennis ball paint will remain fine. The same thing applies to the paint itself. If it can flex a bit it will resist chipping if it can not then there is a problem. Putting more or harder paint on will not eliminate the problem but actually makes it worse. The good news is that the paint application technology has now caught up to the new chemistry and as the plants update their equipment we will see a big improvement in the durability of the finish. The Corvette assembly plant in Bowling Green is shutting down for a bit to change their whole paint system over to the new tech even though what they had was only from 2003. I suspect that the Subaru plant making the Twins may have been a bit behind the curve in the equipment updates.
| Need new windshield | BRZkitty | Northern California | 20 | 05-20-2015 12:09 AM |
| Windshield Writing | FRSure | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 04-03-2014 09:20 AM |
| Is my windshield scratched? | Laika | Issues | Warranty | Recalls / TSB | 24 | 02-13-2013 12:25 AM |
| Windshield Repair | jlu | Northern California | 1 | 02-05-2013 01:23 AM |
| Windshield | IloveBaldEagles | Mid-Atlantic | 3 | 12-05-2012 02:19 AM |
