Old 02-09-2017, 01:03 PM   #15
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Originally Posted by vietspride70 View Post
look good when finished....thanks for the post man.
Thank you. I put the engine oil cooler on the opposite side.
Lunatic is offline   Reply With Quote
The Following 2 Users Say Thank You to Lunatic For This Useful Post:
OfficeLinebacker (06-10-2022), Stimmed (02-09-2017)
Old 02-09-2017, 03:32 PM   #16
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by Lunatic View Post
I was told the clutch pack and valve body would be good for 400 lbs of torque, not HP. HP would be higher.
Torque is what breaks things. Not horsepower. HP is a product of torque.
From the nature of this engine, if you have 400 lb ft of tq, you'll have more hp.
Old 02-09-2017, 04:24 PM   #17
Lunatic
Lunatic's Avatar
Yes, correct, that is my understanding.
The Following User Says Thank You to Lunatic For This Useful Post:
cdrazic93 (02-09-2017)
Old 02-09-2017, 05:07 PM   #18
Stimmed
Stimmed's Avatar
Drives: Toyota 86
I don't think the clutch pack was ever pictured but last time I talked to them they still make it.
Thats good to know will shoot them an email and see what the deal is thanks!
2013 Toyota 86 (IQOf86) - Coyoda Turbo Kit, Perrin 3" Exhaust, 18" CE28SL's, Custom Oil Cooler/Transmission Cooler, Tuned by Coyote Tuning, Built FA20, E85 Fuel, Turbo Kit and Oil Coolers installed by Turbo Yoda
Stimmed is offline   Reply With Quote
Old 02-10-2017, 03:54 AM   #19
Brzerker
Brzerker's Avatar
Drives: World Rally Blue BRZ
@liquidsky44 should be able to chime in
Brzerker is offline   Reply With Quote
Old 02-14-2017, 06:18 AM   #20
Stimmed
Stimmed's Avatar
Drives: Toyota 86
Well mine seems to be slipping now had to dial it back a bit. Contacting a few places about clutch kits for the next stage.
Old 03-07-2017, 07:56 AM   #21
JP86
JP86's Avatar
Drives: Toyota 86 GTS Aero Silver Auto
Nicely done mate!
What size is the cooler? Thinking of doing a similar set up
JP86 is offline   Reply With Quote
Old 03-07-2017, 09:45 AM   #22
Lunatic
Lunatic's Avatar
Originally Posted by JP86 View Post
Nicely done mate!
11" wide, 7" high. Seatab 6 series if I remember correctly.
Old 03-07-2017, 01:30 PM   #23
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
ATF oil cooler does help with the slippage, but the oem clutch pack would not hold the high torque for long. Either way all the parts mentioned above should be replaced for it to hold 300torque.
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
liquidsky44 is offline   Reply With Quote
The Following 2 Users Say Thank You to liquidsky44 For This Useful Post:
Brzerker (03-11-2017), OfficeLinebacker (06-10-2022)
Old 03-07-2017, 08:06 PM   #24
Stimmed
Stimmed's Avatar
Drives: Toyota 86
Even at the power im doing now as long as I didnt try to push over the 400whp anything under it seems to be holding fine with it. Oil cooler helping for sure.
Decided against building the trans further. Cars nuts as it is and im just enjoying it. I also got a spare trans sitting round for if shit does go bad.
Old 03-07-2017, 08:53 PM   #25
tyler_win_photo
tyler_win_photo's Avatar
270whp and 220tq holding well over here. Gonna try to install a tranny cooler in the summer. I think 250tq is close to the limit of the stock trans.
tyler_win_photo is offline   Reply With Quote
Old 03-08-2017, 12:53 PM   #26
Lunatic
Lunatic's Avatar
You bet.
Old 03-08-2017, 01:14 PM   #27
Lunatic
Lunatic's Avatar
Looking good.
liquidsky44 (03-08-2017)
Old 03-09-2017, 03:41 AM   #28
krr150
Drives: toyota86 full opt aero auto
I am at 323 with edelbrock and e-85. Automatic tranny, lots of track days, and no problems at all. I always heard the automatic was actually stronger then the manual. I also run a tranny cooler and normally see 230 to 240 tranny temp on track.
Good to hear it's holding up, I'm really leaning towards the edelbrock s/c. eventually id probably chase 400whp & I know that the boost would be too high for a stock box and tranny
Could you tell me what is the boost psi on the base tune and torque & HP numbers? I don't want a rebuild right away I like to take it step by step for the experience and financial reasons too
Originally Posted by Stimmed View Post
Im at about 300hp right now. And it seems fine. Im just worried cause im hoping to push round 400+ depending on how the transmission holds! Ill be pushing mine more in the next week or so maybe 2 depending on parts arriving. So ill come back and update how its going either way.
Sent from my HUAWEI NXT-L29 using Tapatalk
krr150 is offline   Reply With Quote
Boosted owners in NY - how are you passing state inspections? Foobar NY / NJ / CT / PA 12 10-15-2015 02:02 PM
Auto Trans issue Triumphrider Issues | Warranty | Recalls / TSB 9 11-04-2014 07:34 PM
Is there an Auto Trans only dyno thread? Pure Automotive Engine, Exhaust, Transmission 17 07-17-2014 12:35 AM
Auto Trans Feels like it is slipping... Fett4Real Issues | Warranty | Recalls / TSB 19 01-16-2014 10:02 PM
What is the best way to Launch the Auto Trans DeOppressorLiber Tracking / Autocross / HPDE / Drifting 27 10-22-2013 11:24 PM
