Old 01-20-2017, 02:56 PM   #15
iamjacob
insert witty quip here
Drives: 2016 Limited BRZ
I "combat park" at work by using the backup camera. It gets me straight and centered in the spot every time. No angle issues for me there.
I "combat park" in the garage using the side mirror. Using the mirror lets me get within an inch of the garage cabinets to allow enough room to get a motorcycle in and out between the cars.
iamjacob is offline   Reply With Quote
The Following User Says Thank You to iamjacob For This Useful Post:
why? (01-21-2017)
Old 01-20-2017, 02:59 PM   #16
You throw a camo net over it, leave the doors open and keys in the ignition?
why? (01-21-2017)
Old 01-20-2017, 03:16 PM   #17
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
You don't?
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
The Following 2 Users Say Thank You to Anthony For This Useful Post:
Tcoat (01-20-2017), Ultramaroon (01-20-2017)
Old 01-20-2017, 03:20 PM   #18
Originally Posted by Anthony View Post
You don't?
Only when in Detroit. You would think leaving the doors open and keys in it would be bad there but I will take the quick exit route anytime. You have any idea how hard it was to find a graffitied, crumbling concrete camo net though?
Anthony (01-20-2017), daiheadjai (01-22-2017), why? (01-21-2017)
Old 01-20-2017, 04:13 PM   #19
Teseo
Drives: frs
I thought i was the only one who parked crocked. I guess its because the car is kinda short and a little inpit on yhe steering wheel change the angle
Old 01-20-2017, 04:34 PM   #20
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
I took a little time to get used to parking straight with this car, but now I'm pretty consistent. I usually try to approach perpendicular to the space and cut the wheel in sharply, making small adjustments if I didn't judge quite right. Thankfully the car is so small I could totally jack it up and still have decent clearance all around as long as I'm not touching a line. I think this mostly came down to learning where the car's nose is in space since you can't see it from the cockpit unless your raise the seat enough to jam your head into the roof.
As for backing in (my go-to), I have a process I was taught by my driving instructor that works every time, with virtually any vehicle. I pull past the spot I plan to park in (it's rare for someone around here to steal a space from you when you've got a signal on and you're clearly going for it) getting my shoulder about lined up with the halfway point of the next parking space. Shift to reverse, cut the wheel to lock, and start backing up (no, I don't judge with the camera here because I have half a lifetime of experience and habit of using my eyes, neck muscles, and the rear glass), use side mirrors to make sure I'm not going to give the car next to the space any custom sideswipe paint jobs, and also check for the lines on the ground in my mirrors. Once I know I'm in, I've begun to make use of the camera to double check that I'm straight and to make sure I'm not running up on the curb or a vehcile behind me. This is the only way I can decently back into a space (not talking parallel parking, though). If I try to cheat by entering at anything less than a 90° angle or being already lined up to back straight in, I get all jacked up. But if I pull past the space slightly and cut the wheel, I usually nail it without having to make major adjustments.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following User Says Thank You to Overdrive For This Useful Post:
toijin (01-20-2017)
Old 01-20-2017, 06:06 PM   #21
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
For once...
I HAVE THE ANSWER!!
I had the same trouble when I first got this car; for months, I could swear I was pulling in straight (or backing in straight), then get out of the car only to discover that I was parked diagonally again. Drove me crazy. As you've probably all guessed by now, I'm a little OCD, and parking poorly is something I don't tolerate well, especially when I'm the one doing the poor parking.
You know what it was, at least for me, and I'm guessing for many of you? This car's door is swept up at a fairly severe angle front to back along the slot into which the window retracts. Most cars are either level, or slightly raked upwards. The FR-S/BRZ takes that "slightly raked upwards" to an extreme. If you rely on the sight picture out of your driver and passenger windows to confirm whether or not you're parked straight, that angle will mess with you big time.
The second I realized that's what it was, my parking straightened out.
Check it out...
Barry
MuseChaser is offline   Reply With Quote
The Following 3 Users Say Thank You to MuseChaser For This Useful Post:
funwheeldrive (01-21-2017), Ultramaroon (01-20-2017), Xiijuwa (01-28-2017)
Old 01-20-2017, 06:39 PM   #22
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
I just poke my head out and line myself up parallel to the parking lines..personally I've always felt due to the size and decent visibility this has been one of the easiest cars to park backwards, so I backup nearly every time I'm parking.
HKz is offline   Reply With Quote
The Following User Says Thank You to HKz For This Useful Post:
Old 01-20-2017, 07:07 PM   #23
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
huh.. I always thought I was just shitty at parking..
The Twins make me smile
The Following User Says Thank You to soulreapersteve For This Useful Post:
finch1750 (01-20-2017)
Old 01-20-2017, 07:22 PM   #24
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
I get this all the time. Get out, look at it, then re-park.
Helps that the twins are so small that it usually doesn't matter.
God-level parallel parking skills though. Even in a Grand Caravan.
Some people never will be capable though. Such is life.
Old 01-20-2017, 09:00 PM   #25
humfrz
DANG! ........ 24 posts and counting, on how to park a car straight ......
humfrz
mdm (01-20-2017)
Old 01-20-2017, 09:45 PM   #26
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Leave it like that and it gets left alonr cuz they think it's a bait car
I always look behind me to get centered and not smash into anything, but I look forward to line myself up. And I do this in any vehicle I drive, even my 335is with its downward tilting side mirror.
Looking forward helps alot, assuming the spaces are even on both sides lol
humfrz
OT was slow cuz everyone came out here I guess
humfrz (01-20-2017)
Old 01-20-2017, 10:03 PM   #27
Ultramaroon
not playing cards
Ultramaroon's Avatar
Also in the crooked parking club
I'm a parallel parking commando but I can't back into a space for shit. Glad it's not just me.
I'm going to try @MuseChaser's theory. I also figured it had to have something to do with the lines of the car.
@Anthony, looking forward definitely helps.
Anthony (01-24-2017)
Old 01-20-2017, 10:17 PM   #28
vintagemxer
vintagemxer's Avatar
Drives: 2016 BRZ Limited
I do it on purpose...Makes it much harder for idiots who don't tagging your car with their doors. Of course...that's only if the North 40 is full
vintagemxer is offline   Reply With Quote
Parking at LGA - Parking Spot or Park Plus Marriott WRXcellent NY / NJ / CT / PA 5 01-21-2016 04:43 PM
Crooked Dealership Experience Zyo81 Scion FR-S / Toyota 86 GT86 General Forum 39 12-22-2015 07:49 PM
Is it crooked? becauseracecar1 Cosmetic Modification (Interior/Exterior/Lighting) 18 05-10-2014 09:59 PM
License plate light crooked? (diode dynamics) Vincenttam Cosmetic Modification (Interior/Exterior/Lighting) 7 01-07-2014 11:17 PM
Best Parking Job Ever Mr.Bobbino Off-Topic Lounge [WARNING: NO POLITICS] 15 01-17-2013 08:30 PM
