#15 | |
Drives: 2016 Toyota 86 GT (Auto)
![]() ![]() My SPAL fans are the same 30102029 fans mentioned here... I looked them up and found that each fan draws 14.5 Amps. Now I'm almost sure that Mishimoto's shroud + wiring are the culprit of the low performance of the cooling system. 1- In a simple (for dummies) language would SPAL 30102029 perform better than the OEM or not? assuming I provide the needed Amperage and go back to oem shroud? 2- have you or anyone else fitted the mentioned Spal fans on oem shrouds? 3- do you still recommend the front duct? Bear in mind that I have 0 issues while driving at Norma to highway speeds, the issue arises only at low, high traffic speeds and idling. And the heat climbs up an get stuck there, only goes down if I drive at highway speeds for a while. Thank you for your patience and continued support. Kind Regards ![]() Sent from my SM-N986B using Tapatalk |
#16 | |
Very early on, before I changed to Spal, I fitted the Mishimoto kit, and had significant cooling issues... exactly like you. Turned out one of the fans was wired incorrectly so was "blowing" rather than "sucking". The polarity on one of the connectors had been reveresed in production. I believe this has happened to a couple of other people using the Mishimoto kit. I have since changed to the biggest Spal units I could fit, using the orginal Mishimoto shroud BUT, modified with much bigger enlarged apertures for the larger fans. I use a shroud simply because my cooling issues are very high sustained revs at low road speeds. (the standard Mishimoto kit is adequate for slighly above normal usage, but not a lot more in my opinion). I draw power/ground directly from the battery using heavy duty wiring and relays, amd simply use the old existing fan wiring to "trigger" the new relays. Last edited by grumpysnapper; 06-29-2022 at 09:14 AM. |
#17 | |
Drives: BRZ, STI, GT350R, Supra, 987.2
1) No one knows, OE data is not out there for the general public. 2) Not that I know of. 3) Always. |
#18 | |
Drives: 2017 Hot Lava 86
I am running a Spal fan in place of the AC fan in the oem shroud. I'll have to do some digging to figure out the part number though, it was just a leftover fan from another project a couple years ago. I am still using the oem wiring. I have a k24 swap with the ac deleted, my oem fan comes on first around 190, and the spal comes on second at 200 I believe. My car is a daily and I've put 4k miles or so on the setup without an issue. I was a bit worried about the fan drawing too much amperage but it seems to be doing fine. |
#19 |
Track Day Junkie
Drives: 2022 BRZ Limited
To revive this... I thought I'd share what I'm doing. This is my track car, the new Red 2022 that replaced Blue.
I have an oil cooler in the front. It's on the right, lower side of the radiator area. I have a snorkel for the CAI that comes halfway down on the left side. There's no purpose to fans when racing and moving. There's the rub: when moving. Sometimes I've had to sit in the pit line for five minutes or longer. It's not good to get caught not running and hold people up when it's time to go. I've removed the right fan and I've cut away almost all of the fan shroud that restricts airflow. If need be, the one fan will come on. I plan on posting pictures as I get it all back together. This and the TSS Fab subframe and loosing most of the plastic at the bottom of the bumper fascia will net about a 10 pound loss and I've removed the AC which is good for approximately another 10 pounds. I think the headers and the completely adjustable suspension will help as well. I may get under 2,600 pounds, and that's with the CMS Performance Roll Bar installed. TSS Fab rear subframe is on its way...
Try this Jalapeno son! It ain't hot...
BLUE 2022 BRZ, Scargod's Mod's and Track Upgrades Scargo on IWSTI (Journal of STI track car-for sale) Track Day Videos on YouTube |
| Technical information on the Toyota D-4S system | arghx7 | Engine, Exhaust, Transmission | 72 | 01-13-2025 08:43 PM |
| FS - OEM Radiator and Fans | g0odspeed | Engine, Exhaust, Bolt-Ons | 0 | 01-08-2016 10:54 PM |
| Stock radiator + aftermarket Shroud to fit SPAL fans | jflogerzi | Forced Induction | 18 | 09-08-2014 11:55 PM |
| Radiator Cooling Fans not getting power?? | John Rambo | Issues | Warranty | Recalls / TSB | 13 | 08-27-2014 10:17 PM |
| Question for Subaru veteran repair and ecu guys:radiator fans | Huehuecoyotl | Engine, Exhaust, Transmission | 11 | 04-14-2014 06:19 AM |
