#15 |
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
Hopefully that's all it is! Please let us know how it goes, and good luck!
#16 | |
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
G |
#17 |
Drives: 2013 FR-S, 6MT, Ultramarine
No, the car is STILL in safe mode. And a DOG in the morning when it's cold. I kept driving this evening to burn the gas off, and refilled with fresh 93 today. Hopefully by tomorrow evening I should burn through 1/4 tank and I'll know more. I hope it is good news.....
#18 |
Re-member
Drives: Toyota camry
Bad gas causes knock on only one bank? How does that work? Also, I thought there were knock sensors for each cylinder, perhaps I am wrong. Anyway keep the community updated as this progresses. Thanks for posting
Nothing decays like progress, and nothing preserves like neglect.
#19 |
#20 |
*UPDATE*
The master tech at the dealership is sending my data dump to Toyota tomorrow to get their input on the issue. He said they should have an answer to what to replace/do by tomorrow afternoon. He's also hoping it's just a knock sensor, and he expects it to be a standard Subaru sensor. |
#21 |
Abner, that is crap... Much like ahauseer stated bad gas would effect each individual cylinder, not just one side. I still think it is a bad knock sensor, however keep your head up toyota will take care of you. I still can't wrap my mind around why the car is still in safe mode??? It would have to be an ongoing issue to keep the car in safe mode, fortunately that also points to a faulty sensor. I can't believe some of the dealership mechanics nowadays, they understand how to pull a code, read a manual, but have completely loss the ability to trouble shoot, Sad really.
G |
#22 |
Enjoy it, destroy it.
Drives: Datsun Racing Hen
Yeesh.
First model year woes... probably an overly sensitive knock sensor. Good luck. |
#23 | |
#24 | |
G |
#25 |
As a sad update, my car has been at the dealership for 1 week. Toyota sent an engineer to "inspect" the car last week, and found nothing. His final suggestion was "it's not the gas, replace the knock sensor." WOW! I could have told them that!
So the knock sensor was ordered, and arrived today. However, the dealership won't install it until tomorrow morning. So if the knock sensor does NOT fix the problem, and something else needs to be ordered, there's another week. Am I pissed? YES! It's been almost 3 weeks since the problem occurred. The dealership doesn't seem to be in a hurry, and Toyota doesn't seem concerned. If they have to hold my car beyond tomorrow, I will go from frustrated customer to irate! On a plus/minus note, they gave me a 2012 Scion tC to drive. Plus because the car is free. Minus because it's a tC!! |
#26 |
Engineering Student
Drives: Scion FR-S 2015
how do you read the error code?
How do you put car on Safe mode? |
#27 | |
Drives: corolla 2008
Hi any solution this code p0328 i have corolla 08 with this code and change knock sensor, check circuit, check harness and nothing.. the code is intermitent.. do you habe solution about this....? |
#28 |
Use cheap obd code scanner like this Android Torque software is good.
http://www.ebay.com.au/sch/i.html?_f...lm327&_sacat=0 Car will go into "safe mode" when the ECU or possibly the Transmission computer detects a significant problem or a sensor failure in an attempt to protect engine/trans from further damage. limits throttle and rpm to about 3500 rpm. Won't go back to normal till fault repaired and ecu reset (battery cable removed for short period) |
| Chevrolet Code 130R | Zaku | Other Vehicles & General Automotive Discussions | 66 | 05-29-2013 04:48 AM |
| check engine/CEL/DTC/MIL code list | arghx7 | Engine, Exhaust, Transmission | 3 | 07-04-2012 11:37 PM |
| Check engine light code reader | FRSCoupe | Engine, Exhaust, Transmission | 14 | 06-13-2012 06:06 PM |
| SWP same colour code as IS250 WP? | stevo_12v | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 14 | 04-22-2012 01:36 PM |
