Old 12-21-2016, 05:33 PM   #15
humfrz
Originally Posted by Flame9020 View Post
The dealership claims that it is normal for this transmission since its "new". How likely is it that the synchros could explode?
Usually a synchro won't "explode", it will just get ground up and fall as pieces into the bottom of the crankcase.
humfrz
Old 12-21-2016, 05:52 PM   #16
Ultramaroon
not playing cards
Ultramaroon's Avatar
Once again I didn't install or purchase the kit so I have no idea what to do with it. If it is more trouble than what its worth I might get rid of it.
Yes, I read your OP. As you have no practical experience, I am just sharing mine.
Old 12-21-2016, 06:12 PM   #17
radroach
Drives: car
I also get balked out of 2nd if things aren't warmed up. But I've found ways to prime the gears after a cold start. Just reverse, 20 feet or so, then 1st, then repeat if necessary. The gears get spinning and the syncros well lubed, makes the first couple shifts in the morning easier.
Old 12-21-2016, 06:36 PM   #18
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
Hey guys,
My FR-S has only 10k miles and every since I picked it up in April the car cannot downshift into 2nd gear when its cold. Shifting from 1st to 2nd is a little rough but works however 3rd to 2nd or neutral to 2nd doesn't work period. Now with the winter weather it is only getting worse. It has been to the dealership twice for this issue and they claim that it is "normal" which I think is a load of bull. He did mention a TRD short throw shifter which was installed before I purchased the car. Could this be an issue and does anyone else have this problem when their car is cold.
How many miles when you bought? Any chance a test pilot fucked it over?
geezerbrzeezer is offline   Reply With Quote
Old 12-22-2016, 12:22 AM   #19
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Driven my car plenty of times when its below freezing out and never had an issue. Last winter my car was only at 4k miles (now its at 10k).
It definitely got smoother over time.
It definitely gets smoother as it warms up.
It definitely got smoother after I replaced fluids (last January, approx 4.8k miles).
It definitely got smoother when I added a heavy shift knob (from Anarchy Motive).
^ All things you might want to try. I also don't have a short shifter (of any kind from any brand).
This is my first manual transmission (and car in general), other than stalling the car and missing a gear when shifting in my first few miles, I didnt have any issues with my car when it was new and cold out.
Are you hesitating when you shift? I've noticed sometimes when I hesitate, it'll feel like the gears are grinding a bit. Happens to me when I'm in traffic and I go from first to neutral then back into first (<5 MPH) with some hesitation because I'm expecting traffic to freaking come to a standstill again.
PandaSPUR is offline   Reply With Quote
Old 12-22-2016, 04:41 AM   #20
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
I am using blox weight 1lb for shift knob, it felt much better, but sometime still hard to put in reverse and 1st gear in the cold morning though
FR-Sky is offline   Reply With Quote
Old 12-22-2016, 08:48 AM   #21
catsspat
Drives: 2013 BRZ Premium MT
I have tried double clutching and it didn't seem to make a difference. I also rev match whenever shifting.
Try this:
* Let's say you're on 3rd gear.
* Clutch pedal down.
* Pull gear out to neutral.
* Clutch pedal up.
* Jab the accelerator pedal to spin up the input shaft and all the gears attached to it. Don't keep the accelerator pedal pressed, though. Just rev it quickly and let it go. If you're still pressing down on the clutch pedal when you do this, it won't do anything to the input shaft because it won't affect the clutch and anything past it (input shaft).
* Press clutch pedal while input shaft is still spinning.
* Quickly put it into 2nd gear.
The way to think about it is that the synchros are good at slowing down the transmission side to match flywheel speed, but it's terrible at speeding up the transmission side to do the same. It shouldn't be like this, but we get what we get, so.
catsspat is offline   Reply With Quote
Old 12-22-2016, 11:53 AM   #22
fang_gt86
FR Noob
fang_gt86's Avatar
Throttle blipping helps going into 2nd for me. This may sound weird but I have less stubborn tranny with E85.
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in
fang_gt86 is offline   Reply With Quote
Old 12-22-2016, 12:09 PM   #23
FX86
you know i try to stay away from any tranny
i saw an episode of america's next top model and this one tranny was mocking another girls chia pet wooly mammoth like eyebrows but i was thinking bitch you shouldn't be talking you is a man, wtf
Old 12-22-2016, 12:19 PM   #24
fang_gt86
FR Noob
fang_gt86's Avatar
Not that kind of tranny haha..
Old 12-22-2016, 12:57 PM   #25
Flame9020
Drives: 2015 Scion FR-S
Originally Posted by catsspat View Post
Try this:
* Clutch pedal up.
When the car is cold this doesn't help. When I go to put it into 2nd gear it feels like there is something blocking the shifter from going into 2nd.
Flame9020 is offline   Reply With Quote
Old 12-22-2016, 01:41 PM   #26
Ultramaroon
not playing cards
Did you try spinning it up higher? You have to get it spinning above the speed it would if already in gear. Don't be afraid to really rev it then disengage the clutch quickly before it spins down.
If it improves just after warming up then I don't think there's anything wrong with the trans.
If you change to another fluid like Redline MT90, it will help a little. It will do so at the expense of becoming significantly noisier. Again, this is my firsthand experience.
Old 12-22-2016, 02:16 PM   #27
Venom1506
Drives: 16 Ultramarine FRS
Switching to Motul fluid and rev matching helps a ton but ultimately you just have to let the trans warm up.
Then again im pretty convinced my trans has a bit of an attitude. Some days it will shift through everything perfectly smooth regardless of the temperature. And some days 1st and 2nd are just not having it even if its completely warmed up.
TL;DR Just take some time to learn your trans, they all have their own personalities but new trans fluid and rev matching does help.
Venom1506 is offline   Reply With Quote
Old 12-22-2016, 04:24 PM   #28
Teseo
Drives: frs
But still can feel the clutch "dragging"...
Gear shifting TexasFRS Scion FR-S / Toyota 86 GT86 General Forum 31 05-11-2016 10:29 PM
Shifting from 1st-2nd gear... FRSpappa Engine, Exhaust, Transmission 13 05-24-2014 10:06 PM
3rd gear inconsistent shifting mike the snake Issues | Warranty | Recalls / TSB 30 11-22-2013 03:54 PM
Clicking shifting 2nd gear and R radroach Issues | Warranty | Recalls / TSB 0 03-16-2013 11:36 AM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 02:22 PM
