Old 08-19-2012, 06:56 PM   #15
Rawhyde
Drives: B4C Camaro, 2005 MINI JCW, Civic
Originally Posted by fatoni View Post
have fun with that
It has to be done at some point anyway. It'll be easier in the future if it's taken apart and anti-seized while everything is still new. The shop manual procedure calls for removal of exhaust components and even the exhaust manifold. As unpleasant as it is, it will be much better in the future if thes parts get the same treatment.
A little pain early on is better than than a lot of pain from stuck or broken bolts later on. I keep my cars for a long time and I do my own work once the warranty expires, so I try to make it easy on myself.
Rawhyde is offline   Reply With Quote
Old 08-27-2012, 03:00 PM   #16
Chad
Chad's Avatar
Drives: FR-S Whiteout
Originally Posted by Rawhyde View Post
I have a PM routine I do on every new car I buy. As soon as I get it home , I :
1. Change the oil & filter. I use a clean pan to catch the oil and look for contaminants. I also cut open the filter and inspect it.
2. Check ALL fluid levels.
3. Check tire pressures.
4. Remove the wheels. Wash, dry, and wax them inside and out.
5. Remove any screws or bolts holding the brake rotor to the hub, apply anti-seize, and reinstall.
6. Apply anti-seize to the lugs, install the wheels, and torque them to spec.
7. Remove spark plugs, apply anti-seize to the threads, apply SMALL amount of dielectric grease to the insulators, and reinstall.
8. Hard wire my radar detector.
9. Spray the upholstery with Scotchguard or similar.
10. Install any "dealer accessories" like self dimming mirrors, floormats, trunk mats, etc.
11. Wash and wax the car if the build date indicates the car is more than six weeks old. If it is newer than that, I wait for a month or so for the paint to cure.
Then, I drive and enjoy the car.
At 500 miles, I change the oil and filter.
At 1000 miles, I change the oil and filter.
After that, I change the oil and filter every 2,500-3,000 miles.
Do you want to come do this to mine?
Chad is offline   Reply With Quote
1/4 Mile times Boosted2.0 Tracking / Autocross / HPDE / Drifting 368 02-13-2021 07:52 AM
1000+ miles jarviz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 31 02-02-2013 12:23 AM
1000 miles jarviz Scion FR-S / Toyota 86 GT86 General Forum 8 06-29-2012 02:42 PM
3000 mile review. Superhatch BRZ First-Gen (2012+) — General Topics 7 06-18-2012 10:33 PM
