Old 04-07-2011, 09:38 PM   #15
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by Exage View Post
Ideally and put very simply a de-stroked (and 1.5-1.6 rod to stroke) FB25, with a beefier/smaller cylinder bore reduced to 2.0L with a higher compression ratio (11:1-12:1). AVCS, and D-4S. Revised heads, intake and exhaust manifold, camshaft. Optimized ignition and fuel mapping.
Interesting idea, EJ's can mix and match cranks to fiddle with odd combinations. However the FB's are both 90mm stroke, and probably share the same crank. Unless a smaller FB that can share its crank is on the way I don't see a de-stroked FB25 happening.
Oh wait... You could be on to something if they already have that in mind for the next gen WRX/STi!
Because titanium.
Old 04-07-2011, 10:01 PM   #16
-TokenSX-
-TokenSX-'s Avatar
Drives: Nissan Silvia
Originally Posted by Fortunate Few View Post
2.0T is what im hoping for. I don't think i'd go for 2.5.
Same here 100% on dat : D
-TokenSX- is offline   Reply With Quote
Old 04-07-2011, 11:03 PM   #17
Exage
GL 86!
Exage's Avatar
Drives: Maybe FR-S... maybe not
Originally Posted by tranzformer View Post
This might be a dumb question, but what is gained by destroking an engine (say from 2.5L to 2.0L) vs. boring a 1.8L to 2.0L? Do you gain something in the process (durability, revs, tq....etc.) or is a 2.0L a 2.0L?
I've been tooting the rod-stroke ratio horn for a couple days now. De-stroking would cause less mean (aka average) piston speed at the cost of less displacement however you can put in a longer connecting rod if it's up to strength and the engine would be able to withstand and produce peak horsepower at a higher rpm, I also stated a smaller bore then the FB25 94mm just to beef it up.
Any increase and decrease in stroke or bore will effect the ultimate torque and power of the engine.
Is a 2.0L a 2.0L. No! Look at my 2ZZ-GE Vs. a 1ZZ-FE. Both displace 1.8L, both are very different animals... I'd be happy to try and explain it in more detail on the engine tech thread if you'd like!
@Dimman I doubt it too, but you never know what will happen. I simply thought up this engine months ago trying to reverse engineer the FB20 to make it high rpm suitable! Seeing as the EJ were usually over square led to this idea.
Exage is offline   Reply With Quote
Old 04-08-2011, 02:45 AM   #18
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
yeah, it's really incredible how important that ratio is. i remember when i learned about it my brain more or less exploded, haha.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 04-08-2011, 04:55 AM   #19
ryun84
ryun84's Avatar
Drives: 04 PSM WRX Wagon
Shouldn't this be a poll? I'd pick whichever engine revs higher. If the 2.5L can be made to rev just as high as the 2.0L can (and I don't know if that is possible), then I'd go for the larger displacement because the American in me just likes it that way.
ryun84 is offline   Reply With Quote
Old 04-08-2011, 06:49 PM   #20
Allch Chcar
Drives: N/A
Not if Subaru moves foward with downsizing everything. They are making a 1.6L Turbo for the next gen Impreza according to rumors.
I think the FB with 2 liters will be plenty, there's always the turbo option. I'll probably wait and see what becomes of the 1.6Liter turbo though.
Allch Chcar is offline   Reply With Quote
Old 04-08-2011, 09:30 PM   #21
Dimman
Kuruma Otaku
Dimman's Avatar
I must've been sleeping to miss that 1.6T rumour. Maybe they are getting back into the WRC and are homologating a motor?
Could end up being that an FB25's bore with this 1.6's crank (assuming it's a high performance short stroke motor to meet WRC requirements) could end up being 2.0L.
But I'm not seeing that happening right away if the 1.6T is still in the rumour stage.
Because titanium.
Old 04-08-2011, 10:57 PM   #22
Allch Chcar
Drives: N/A
Yes it's all about the WRC. And it is still very much just a rumor as far as I know. It was announced about when they announced the jointly built Impreza STi CS400 with Cosworth. I tried to trace the rumor but it leads into Italian websites and dead ends at http://www.auto.it/autosprint/ so far. They're actually suggesting sometime in 2012 :crazy: and one site went so far as to suggest it would replace the base 1.5L engine which is pretty far out there for a rumor .
Old 04-12-2011, 08:51 AM   #23
ljstella
Drives: 2007 Subaru Impreza
I still don't know how credible that would be, considering the new WRC formula mandates an inline 4, which would rule out a boxer engine. While its possible, I wouldn't expect to see it here in the US.
ljstella is offline   Reply With Quote
Old 04-12-2011, 06:24 PM   #24
aliphian
Dreamer
aliphian's Avatar
Drives: Nutless Grocery Getter
Wouldn't it be IRONIC if they used a Toyota inline 4 for the new STI.
"Reality is merely an illusion, albeit a very persistent one."
aliphian is offline   Reply With Quote
Old 04-13-2011, 02:49 AM   #25
ryun84
ryun84's Avatar
I'd jump right on it if Subaru used Toyota's inline 6 for their new STI! o_O
Old 04-13-2011, 06:52 AM   #26
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
2.5l>2.0T>2.0. The reason I put turbo in the middle is because of possible extra reliability and maintenance issues. I have a 2.0 in a 2800 lb car so I don't think I would be more impressed.
SUB-FT86 is offline   Reply With Quote
Old 04-13-2011, 11:47 AM   #27
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Yeah but sadly you won't see that ver here in US. Japan have been selling 1.5L ver over in Japan for a while, but not in US.
Old 04-13-2011, 10:05 PM   #28
Allch Chcar
Drives: N/A
Yeah but but this one haz a turbo .
hi guys jim86 CANADA 4 09-28-2011 12:42 PM
What color would you guys choose to buy? jyoo Scion FR-S / Toyota 86 GT86 General Forum 125 04-29-2011 05:23 PM
When do you guys think the FT-86 go into production? latino469 Scion FR-S / Toyota 86 GT86 General Forum 15 02-09-2010 07:31 PM
What do you guys think?? Arcangel Scion FR-S / Toyota 86 GT86 General Forum 19 10-30-2009 11:06 AM
