Old 11-02-2016, 02:32 PM   #15
Teseo
Drives: frs
Nope :/ he told me it would cost a lot then when he gave me the price my jaw dropped lol. Still gonna get it probably lol
#carpriorities
Old 11-02-2016, 02:53 PM   #16
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Live gauges are a yes. Trying to find out about alarms.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 11-02-2016, 03:06 PM   #17
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Updated OP with relevant information from Ben Linney.
Old 11-02-2016, 03:07 PM   #18
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
This needs to support android soon!!
Old 11-02-2016, 04:15 PM   #19
Luftwaffel
Boost Creep
Luftwaffel's Avatar
More information added along with link at the bottom to EcuTeK release.
Old 11-03-2016, 02:33 PM   #20
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
man this is sooo much win. just hope it looks nice. Accurate readings of oil temp.. here we go.. finally.
mokinbird87 is offline   Reply With Quote
Old 11-03-2016, 09:34 PM   #21
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Where are you getting inaccurate oil temps? Torque and ProECU are exactly the same for me.
Old 11-04-2016, 12:05 AM   #22
dj2020
Would this Bluetooth solution be fast enough to show accurate boost and AF readings. No lag in readings? Just as good as dedicated boost/af gauge, i.e. AEM, Defi?
My Dashcommand and Bluetooth OBD2 dongle set up is pretty laggy when it comes to MAP and AF readings.
dj2020 is offline   Reply With Quote
Old 11-04-2016, 05:27 AM   #23
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Honestly I'm not holding my breath. I've been messing with OBD monitoring solutions for a really long time and I have yet to see a Bluetooth solution that doesn't lag.
TBH though, I don't need most of the things I'd display to be fully realtime. I do run a single multi gauge though for boost, AFR, and E% though, the stuff I'd want to be realtime. I'd run temps and FBKC and DAM on the app... a little delay in those wouldn't bother me.
Old 11-04-2016, 05:34 AM   #24
Kodename47
Kodename47's Avatar
Drives: UK GT86
The suggestion is that this will log faster than ProECU. Therefore no reason why you couldn't. Usually the reason why the BT devices lag is due to the fact that the OBD polling rate is slow.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-05-2016, 12:25 AM   #25
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
I'd buy this just for the ability to datalog using just my phone.
But at $300, I'll continue to lug around the ECUtek cable and my beater laptop.
menikmati is offline   Reply With Quote
Old 11-06-2016, 05:34 AM   #26
steve99
Wouln,t it be more to do with most apps like torque dash command etc are using standard obd pid calls to ecu, where as stuff like ecutek oft tactrix are making direct ecu ram address reads which is way faster.
The data rate over blutooth should be heaps fast enough for some log data
Old 11-06-2016, 01:44 PM   #27
Luftwaffel
Boost Creep
Luftwaffel's Avatar
No, it's 100% something to do with Bluetooth. If I force the same protocol/data rate with Bluetooth, there's still a delay. USB is effectively instantaneous. This is with OBDLink SX USB and Torque from last night actually. I gave my Bluetooth adapter away so I can't show a comparison but there's somewhere on the order of 300-700ms delay with Bluetooth.
[ame="https://www.youtube.com/watch?v=x8zHD6tfcjo"]Torque and OBDLink SX - YouTube[/ame]
So, basically, I agree the data rate is fine. Actually, the OBD data rate is 500 Kbps which translates to around 250-300 PIDs/sec. SSM can only be faster. My gripe is the latency makes live gauges just kind of... barely acceptable?
Old 11-10-2016, 04:39 PM   #28
BWilky
BWilky's Avatar
Drives: 2016 Subaru BRZ WRB
Is this going to allow for tuning and replace the ProECU Programming Kit?
Then would you still need to get a tune?
BWilky is offline   Reply With Quote
Delicious Tuning Q & A - FlexFuel BlueTooth Kits for EcuTeK ProECU RaceROM DeliciousTuning Software Tuning 331 06-17-2025 02:36 PM
My Bluetooth in my 2014 FRS so stay connect Case1010 Electronics | Audio | NAV | Infotainment 3 02-24-2016 06:57 PM
Header/overpipe interface misooscar Engine, Exhaust, Transmission 4 11-22-2014 11:21 PM
Garmin GPS Bluetooth Won't Connect frssfo Electronics | Audio | NAV | Infotainment 0 08-20-2014 10:55 PM
Bluetooth connect mutes android NAV Rob_g Electronics | Audio | NAV | Infotainment 6 07-04-2012 04:38 PM
