Old 10-29-2016, 10:14 PM   #15
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
Sorry lost the plot. Just realized we were basing this around an already wider wheel >.<'
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
Old 11-06-2016, 02:40 PM   #16
rascasse
Drives: DGM GT86, half leather, RPS, Nav
Sorry to thread jack my American cousins but i wanted to ask for some advice..
I just swapped my primacies to Continental Sport Contact 5 in the stock 215/45 size and think they're still pretty rubbish with the car still moving about when i don't want it to and in the wet i still find it far too wild. I'll admit they're better than the stock tyres but that wasn't going to be difficult lol.
My question is do i just put this down to they're still a 215 section tyre and i need more width? If so what would you guys recommend? I want the car to be more like a Cayman and grip with precision..
I should say my car is n/a on stock suspension and is a GT86..
rascasse is offline   Reply With Quote
Old 11-06-2016, 06:00 PM   #17
Tokay444
No. My RE-71Rs ons stock size have too much grip for the oe suspension/aligment settings.
The Following User Says Thank You to Tokay444 For This Useful Post:
CatDaddysBBQ (11-07-2016)
Old 11-06-2016, 10:49 PM   #18
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Read this article for a little insight. http://www.roadandtrack.com/car-cult...ransformation/
JimmyMac is offline   Reply With Quote
Old 11-07-2016, 07:37 AM   #19
rascasse
Thanks but I've already read that...maybe I should of gone for the Dunlops over the Contis but in England I think we only get supplied the Sport Max Dunlops...
Old 11-12-2016, 08:43 PM   #20
mrg666
pessimistic skeptic
mrg666's Avatar
I have just replaced stock 215/45-17 Bridgestone Turanza EL400 tires with 225/45-17 Yokohama Advan Sport AS on stock rims. The ride quality has improved noticeably, grip improvement was dramatic. The car feels much more planted on the curves with less oversteering and softer on the bumps. There is no noticeable change in gas mileage and acceleration.
Edit: pictures added
The Following 2 Users Say Thank You to mrg666 For This Useful Post:
Capt Spaulding (11-12-2016), Mr.Impreza (11-23-2016)
Old 11-13-2016, 01:01 PM   #21
Norinradd
Drives: 2013 frs
215/45 on 17x8.25. Anybody done it?
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
Norinradd is offline   Reply With Quote
Old 11-13-2016, 01:28 PM   #22
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
How well do the 225's fit? I heard that it plays with the sidewall and turning a little bit, which i guess is good from your experience.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 11-13-2016, 01:44 PM   #23
shellslinger
Drives: Whiteout FRS
I'm currently running 225/45/17 on 17x9 rim. It looks stretched I'm willing to bet it'll look fine on 17x8 though. Switching over to 245/40 sport comp 2 next weekend
shellslinger is offline   Reply With Quote
Old 11-13-2016, 02:16 PM   #24
mrg666
pessimistic skeptic
mrg666's Avatar
They fit perfectly on the stock 17x7 rims. Compared to Turanza's, I don't feel any play. But 215 Turanza's had very little grip compared to this tire; they were easily drifting/oversteering at the corners. I need to have the same grip to compare sidewall flex. When compared with 215 width of the same Yokohama, theoretically there can be a little more cornering flex on the sidewalls but I highly doubt I can feel it without pushing the car to extreme limits. 225 tires are within the acceptable range of 7" wheels; there is no extreme bulge at the sidewall to cause excessive flex.
My experience is all positive. I will continue with 225 tires from now on. Plus, 225 width looks better to me since they fill the wheel-well better and might protect against curb rash.
Old 11-13-2016, 02:19 PM   #25
MurderousPandas
Kinda scares me with the flex. I wanted to up to the 225, but i had a cracked ring around my tire's sidewall when i was on 215's, the tire guy said it was from taking corners too hard, and i haven't tracked the car yet
Old 11-13-2016, 02:30 PM   #26
mrg666
pessimistic skeptic
mrg666's Avatar
I would make sure the tires are not underinflated. Just by cornering, you shouldn't be able to break the steel belt unless the tire is defective or without proper pressure, regardless of 225 or 215. Such tire damage usually happen because of hitting a pot hole or curb especially with underinflated lower profile tires. 225 should be have better protection against potholes.
Old 11-13-2016, 02:41 PM   #27
MurderousPandas
I would make sure the tires are not underinflated. You shouldn't be able to crack the ring with proper pressure and good quality tire, regardless 225 or 215.
It was at 32, which i think is a good medium between track and street. I really want to blame the tires as it hasn't happened again yet and i use different tires now.
Old 11-13-2016, 02:43 PM   #28
mrg666
pessimistic skeptic
mrg666's Avatar
I use 35-36 psi for street.
