Old 10-27-2019, 05:34 PM   #15
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by Tristor View Post
WD-40 is primarily a solvent, not a lubricant. It can temporarily stop squeaks but an aerosol fluid film like Corrosion-X or similar is a much better bet. If you can, use a grease gun and suspension grease like AMSOil Dominator Racing Lube and grease your bushings under pressure.
Correct but it works and doesn't attract a shit ton of dirt. Not as bad as oils or grease. Fluid film is fantastic but makes a mess...Ohlins actually specs WD40 in their manual.
Here you can read up on WD40 myths
https://www.wd40.com/myths-legends-fun-facts/
Old 10-27-2019, 10:58 PM   #16
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
Well, WD-40 contains a good amount of mineral oil which means it is pretty good on rubber and plastic polymers, can work to help prevent them from drying and cracking, but because of how thin it is and the fact it evaporates quickly it often acts more to clean the area of dirt and debris and less to lubricate it. It lubricates while wet, but it doesn't stay like a grease or fluid film does. Once it evaporates you could be worse off than you started as it tends to displace any grease that was remaining from initial installation. As a general rule I use suspension-specific grease or wheel bearing grease when lubricating suspension components and I try to do it either under pressure (if it's got a zerk, even better) or I remove and reinstall the part in order to fully and properly lubricate it.
A lot of people don't understand that once you start modifying your suspension that the maintenance required goes up considerably. But if you do it correctly, these components will last a long time and perform at their peak.
Tristor is offline   Reply With Quote
Old 10-27-2019, 11:04 PM   #17
new2subaru
Weight Weenie
Drives: 15 FR-S
Page 10. I clean them after every track day.
https://www.ohlins.com/app/uploads/w...nsOriginal.pdf
I generally do what the manufacturer suggests, especially a company like Ohlins.
Windows Squeaking Froylavin Issues | Warranty | Recalls / TSB 164 02-24-2018 01:41 PM
clutch squeaking impossible Engine, Exhaust, Transmission 3 05-11-2016 08:48 AM
Clutch squeaking dallenj Engine, Exhaust, Transmission 14 05-03-2016 12:17 PM
Help! Coilovers squeaking Sw33tm1x Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 01-20-2016 12:05 PM
Squeaking windows bdanisi Scion FR-S / Toyota 86 GT86 General Forum 29 02-10-2013 10:54 AM
