Old 09-27-2016, 02:30 PM   #15
c4lvinnn
Drives: Toyobaruion
You cannot omit all these crucial variables to find your "hard and fast" rule. Period. Go and tinker and look at other threads for fitment.
And aesthetics only for changing 7" wheel offset? Ever see chicken legs on a fat person? Thats not really achieving much aesthetic there.
Dont skip leg day, bro.
c4lvinnn is offline   Reply With Quote
Old 09-27-2016, 02:40 PM   #16
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Funny. Every see the lotus Elise? With those skinny-ass wheels? Doesn't look all that bad.
Also, not strictly aestheics. I'm losing 7 lbs per wheel, 1.5 lb per tire over stocks, and 16 lbs per brake, as I'm doing those at the same time.
That's 98 pounds of unsprung weight off the car, and that's before the cast-iron uprights come off for aluminum ones.. That's another 6.5 lbs per corner, and then we address the control arms and coilovers. I'll have nearly 150 lbs out of the car on just the suspension.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 09-27-2016, 02:40 PM   #17
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by Spartarus View Post
Why not? The car handles great on N3000 215/45/17 tires. Why add a bunch more grip? I don't need it. I'm not building the fastest car in the world, I'm building a car with great handling that handles really well at the limit. It drifts great, and the final power will be sub-300 at the wheels. Why get an 8.5 inch wheel and a 245 section tire if I can't spin the f*ck out of it, smoke the tire, and have a grand old time?
The only reason I'm not keeping the stock offset is I hate the way it looks. This is an aesthetics-only modification. All I'm doing is making sure I'm not sacrificing function for aesthetics.
I can spin my 245 MPSS on a 18x9. Stock engine auto trans.
How many other frs/brz have you driven? What tire wheel did they have?
strat61caster (09-27-2016)
Old 09-27-2016, 02:42 PM   #18
strat61caster
strat61caster's Avatar
imo extended studs, cheap spacers, lots of experimentation and patience. It is hard to get 17x7's to rub without doing something silly.
Personal anecdote: I put my 17x9 +45 RPF1's on with 245/40 tires, removed the springs and let the car sit on the bumpstops, no rubbing or clearance issues anywhere (front struts were changed to a 2.25" spring so that will be your first hurdle, although not the direction you are concerned with). As far as I'm concerned you have nearly +/-1" of clearance for offset tweaks if you stick with 17x7's. Those front wheels at full lock rub the inner fender liners but clear no problem with a 5mm spacer, the +35's are more common for that reason (among others).
For reference, the picture on the left side will show how much bigger and further outboard many have gone without issue, regardless of ride height. This might be your best tool to compare what 'fits' in the fitment thread, and what looks pretty in the pictures to what you want to do.
http://www.willtheyfit.com/index.php...t2=35#isPage=2
Since you mentioned it, SCCA Street class has rules about changing the OE offset, something small like +/-3 or 5mm is the maximum allowed. Since you mention aftermarket suspension though I don't think STX and above has any rules about changing offset.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
c4lvinnn (09-27-2016), Leonardo (09-27-2016)
Old 09-27-2016, 02:55 PM   #19
Spartarus
...Just add nauseum
Spartarus's Avatar
Thanks. That's exactly what I was looking for.
-Spartarus
Old 09-27-2016, 03:03 PM   #20
Spartarus
...Just add nauseum
Spartarus's Avatar
Haven't driven many twins. Mostly other cars. Couple of turbo FRS's, 1 eforce car, nothing bigger than 18x8. No tire bigger than 245.
The bigger tire setup did the power-slide job alright, but the car felt bigger, heavier... It liked to push more during forward weight transfer in a corner, needed power to rotate. It just didn't handle as well. I'll give you that the entry speeds were marginally faster, but it just didn't feel as spritely. It felt like a Mustang. Stock suspension, btw.
-Spartarus
The Following 3 Users Say Thank You to Spartarus For This Useful Post:
churchx (09-27-2016), Leonardo (09-27-2016), Ultramaroon (09-27-2016)
Old 09-27-2016, 03:29 PM   #21
strat61caster
Competitive STX autocross cars have no problem spinning the tires at launch or hanging the back end out on 17x9 245 sticky as fuck RE-71R's with just a header and tune. Hell I can do it on mine right now with a stock powertrain as I'm developing my setup and my car is just too loose.
Sticky 245's aren't a death sentence for fun. I totally understand not needing or wanting more tire though.
ineedyourdiddly
Old 09-27-2016, 03:31 PM   #22
Spartarus
...Just add nauseum
Spartarus's Avatar
Well, that's interesting. I'm open-minded.
I'm nearly certain STX prohibits me from using forced induction, which would seriously suck, but I haven't read the appendix to find out if there are certain approved applications for the FRS.
-Spartarus
Old 09-27-2016, 04:24 PM   #23
strat61caster
That's correct, FI puts you into SM class, which is affectionately dubbed 'Spend Money' which you likely won't be competitive in. IMO just build what makes you happy and if you autocross/time trial go out there to have fun. If you want to win don't spend a cent until you know exactly what you want/need.
http://www.ft86club.com/forums/showthread.php?p=2192626
Some decent tire info for you in there as well.
But the point in the above post is that while you may not 'need' more tire, I'm willing to bet someone with experience could drive your car at 10/10ths, get out and the first words out of their mouth would be 'needs more grip' even at <250 whp levels with 215 street tires.
ineedyourdiddly
Old 09-27-2016, 05:02 PM   #24
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
This is why I want to try RE-71R's in the stock 215 size. I want more grip, but not a ton, just enough to put the power down in corner exits without going all dorifto.
Okay maybe a little dorifto.. But less than it does now.
-Josh
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
Spartarus (09-27-2016), Ultramaroon (09-27-2016)
Old 09-27-2016, 05:21 PM   #25
Spartarus
...Just add nauseum
Spartarus's Avatar
That's awesome advice. I'm not out to win a whole bunch of races in this car...
I'm after a setup that I can push to 10/10ths everywhere... I have that right now, I'm just trying to make small improvements to address things I don't like, without ruining it. I'm good at that, but it involves lots of overthinking things.
For you motorcycle people, this is the SV650 of cars. I want to keep it that way.
-Spartarus
The Following User Says Thank You to Spartarus For This Useful Post:
Old 09-27-2016, 05:45 PM   #26
c4lvinnn
Drives: Toyobaruion
You're also good at overthinking things, lol.
And I have a SV650 too.
The Following User Says Thank You to c4lvinnn For This Useful Post:
Old 09-27-2016, 07:08 PM   #27
Ultramaroon
not playing cards
Ultramaroon's Avatar
-Josh
lol
Yoshoobaroo (09-28-2016)
Load Limits Nah Software Tuning 3 07-15-2016 11:30 PM
Power and Speed Limits Vision86 Scion FR-S / Toyota 86 GT86 General Forum 101 01-15-2016 11:45 PM
Manual Transmission Limits? Tansey86 Engine, Exhaust, Transmission 22 07-18-2014 08:00 PM
Are politics off limits? Longhorn248 Site Announcements / Questions / Issues 35 05-16-2012 11:24 PM
why obsess over rev limits? fatoni Other Vehicles & General Automotive Discussions 39 10-12-2011 12:09 AM
