Old 02-10-2010, 09:06 PM   #15
Lexicon101
Inexperienced
Lexicon101's Avatar
Drives: Crappy old '90 civic. Frankie.
That's why they'll put it on the dash next to the red triangle button (the e-blinkers)... that's not something they'd want susy bubblegum dropping her handbag on and skidding out into the middle of an intersection because of it.
I'd like to see them bring it to production.
Lexicon101 is offline   Reply With Quote
Old 02-11-2010, 02:53 PM   #16
OldSkoolToys
Is a Monster
OldSkoolToys's Avatar
Drives: AE86, MA70
Originally Posted by 4agze View Post
on wet condition you may want to turn that ABS on, but best way to appreciate ABS is to practice on a non ABS car thats why the AE86 is a great teacher makes you enhance the feel or understand the brake feed back and teaches you how to react on a wheel lock.
The 86 has taught me much. Mostly that old cars break down too much. But also how to actually drive.
OldSkoolToys is offline   Reply With Quote
Old 02-11-2010, 03:57 PM   #17
Siriusly.Andrew
Siriusly.Andrew's Avatar
Drives: 1995 Civic DX
ABS + Snow & Ice = Oh Shit Oh Shit
Tires locking on Ice and Snow is good. Bad if you're trying to turn and you lock them up, but for stopping its good. It works like a plow and builds up more snow and crap in front of the tires and slows you down faster than braking. ABS just lets you roll over the snow and never build up that wall to slow you down. Great for pavement though
Originally Posted by MatadorRacing_F1 View Post
Anyway, as i was saying, "speed is expensive, how fast are you willing to spend?"
Siriusly.Andrew is offline   Reply With Quote
Old 02-17-2010, 02:33 PM   #18
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Nice eye, I sure wouldnt mind it... better than having to pull the fuse and have that stupid light bother me.
chulooz is offline   Reply With Quote
Old 04-02-2010, 10:58 AM   #19
jp1598
Drives: 96 Tacoma
Toyota is billing this car as a factory drift machine, as such being able to disengage abs and esc is a must. Hopefully Toyota doesn't get gun shy after the recent unpleasantness.
jp1598 is offline   Reply With Quote
Old 04-03-2010, 03:02 PM   #20
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Are you sure bout that? It makes sense if you're braking straight and stopped straight. Most of the time when ABS locks on the snow/ice, half of the time it spins due to F/R brake pressures are difference.
Old 04-20-2010, 08:38 PM   #21
nimixes
Drives: 1991 Celica GT-S, 3SGTE swap
Tires locking up on ice and snow is not good. Lived in Canada all my life, never heard that nor has it proven useful in any of the situations I have been in.
nimixes is offline   Reply With Quote
Old 04-20-2010, 10:47 PM   #22
Siriusly.Andrew
In many instances ABS increases braking distance in snow/gravel/slush conditions.
There are many people who have personally done this test - I recommend you do as well because its like night and day difference.
find and remove the fuse for your ABS system. Do an emergency stop on an icy surface. mark distance.. Replace the fuse and reattempt the same test and watch as you ROLL past your previous stop point.
"Testing also shows that good snow tires reduce the stopping distance of ABS-equipped vehicles in winter conditions (Transport Canada urges the installation of four snow tires to maintain equal traction on each wheel). Nevertheless, it’s recommended that drivers allow for a longer stopping distance with ABS than for conventional brakes when driving on gravel, sand, ice, snow and mud. This is because the rotating tire will stay on top of these low-traction road surfaces and effectively “float” on the boundary layer. (Conversely, a non-ABS-braked vehicle can lock its tires and create a snowplow effect in front of the tires that helps slow the vehicle. These locked tires can often find more traction below this “boundary layer.”)"
http://www.canadiandriver.com/2005/0...ock-brakes.htm
ABS increases the ability for YOU to maintain vehicle direction / stability.
ABS button....means ABS be turned off? Shadowsong6 Scion FR-S / Toyota 86 GT86 General Forum 35 12-06-2009 01:20 AM
