Old 09-18-2016, 10:29 PM   #15
86wtywly
Drives: 2014 Scion Frs
Originally Posted by Th3rdSun View Post
Firestone does lifetime alignments. Pay once,and go back and get it aligned for free for as long as you own the car.
Toe angel kills tires faster than anything. You really don't want any toe angle at all for a daily driver.
that means zero toe all around? will that fix my floaty steering issue?
86wtywly is offline   Reply With Quote
Old 09-18-2016, 10:49 PM   #16
Racecomp Engineering
Agreed, your toe needs fixing.
- Andrew
Old 09-18-2016, 10:58 PM   #17
swarb
The issue is YOU. Or too much air pressure in the tires, around 32psi should be good.
Your alignment is fine. Getting a performance alignment won't solve anything as it is ok as is, and any alignment change won't make it feel any less "light feeling" other than adding negative camber(install camber bolts). But that does not explain why the 2014 felt better in your hands.
Have you been lifting weights since the last time you drove the 2014 two years ago?
Those of you trying to help, refer to this thread.
http://www.ft86club.com/forums/showthread.php?t=110380
Op wants to fix "light feeling" steering when compared to a 2014 model he drove TWO YEARS AGO.
He tests drives another 2016 and it felt the same.
He was driving a evo x with heavier steering since the last time he drove a frs TWO YEARS AGO.
Old 09-18-2016, 11:09 PM   #18
86wtywly
- Andrew
what is your recommended setup for a stock car?
Old 09-18-2016, 11:35 PM   #19
swarb
Originally Posted by gramicci101 View Post
Right off the bat, your toe is fucked up, front and rear. Technically they all look to be within OEM spec, but OEM spec is a range that leaves a bit of variance, not a number. Go to a performance alignment shop and get it aligned to a number. Shoot for 0 toe in the front and slight toe-in in the rear. I'm guessing the slight toe out on the front and a lot of toe out on the rear is what's giving you the floaty feeling, but others will be able to say more than I can.
I tagged RCE; hopefully they come and offer their expertise.
Positive toe is actually toe-in.
He never mentioned floaty feeing. Only light feeling steering.
Like mentioned by gramicci101, Zero toe in front and slight toe-in in the rear. This will actually make your steering lighter(I doubt you'll notice) as the toe-in from before, the tires were pushing towards the center of the car, making steering slower.
Are you seriously basing your comparison to a car you drove TWO YEARS AGO? Do you remember what you had for lunch that day?
Old 09-18-2016, 11:41 PM   #20
86wtywly
yea i did, i had popcorn for lunch on that day.
So you are saying that alignment setup will have no effect on the steering feel whatsoever correct?
Old 09-18-2016, 11:47 PM   #21
swarb
Did you read what you quoted?
Did you read my other post?
Apparently not.
Old 09-19-2016, 07:09 AM   #22
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
A tire shop thinks that toe align is ok? I'd go to another shop because its way way out of alignment
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
Old 09-19-2016, 07:21 AM   #23
Cole
Not a troll
Cole's Avatar
False. It's within OEM spec. It's not out of alignment. Just not ideal
Old 09-19-2016, 08:45 AM   #24
DirtDrift
DirtDrift's Avatar
Drives: 2016 FR-S
Originally Posted by Norville Rogers View Post
Get it aligned properly for peace of mind. Then you'll know what you have to live with.
^ This.
Although your alignment is within specification the "Total Toe" numbers you're showing us don't give enough information. I'd be more interested in individual toe from side to side, in relation to front and rear.
I'm a very picky person and would align my car closest to spec as possible. Most cars won't feel much different when they're out that slightly, but the twins are very sensitive vehicles.
If you have a "light" steering feel I'd be more inclined to look at the tire inflation and tire wear. There's just too many things that come into play with a light steering feel, other than the alignment which is within spec.
DirtDrift is offline   Reply With Quote
Spring and damper rates: front vs rear, explanation needed Ashikabi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 03-14-2015 04:21 PM
Wheel jargon explanation please nzer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 10-29-2012 04:09 AM
Exhaust parts explanation JoeBoxer Engine, Exhaust, Transmission 10 09-13-2012 07:46 PM
Explanation on the different driving modes? WatchmaN Scion FR-S / Toyota 86 GT86 General Forum 11 08-02-2012 07:36 AM
Scion's Explanation of BRZ FR-S Limited Slip Differential stalon320 Engine, Exhaust, Transmission 5 06-22-2012 11:26 AM
