Old 07-16-2012, 02:49 PM   #15
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by Ichito240 View Post
Even at $1000 per rim its seems excessive for this design wheel. Just one mans opinion though.
Agreed unless they are magnesium and 14lbs or less.
Old 07-16-2012, 03:18 PM   #16
chadz
chadz's Avatar
Drives: 2013 brz limited
Konig has the same wheels but probably not forged. They only come in 17x7 and 14 lbs. If you look closely, you can see it says TS06. http://www.discounttiredirect.com/pr...onday.g.xl.jpg Maybe from the same mold?
chadz is offline   Reply With Quote
Old 07-16-2012, 04:07 PM   #17
Ichito240
Finally a BRZ owner :)
Drives: 2017 BRZ Limited
If your interested in the look, then that Konig seems like it is from the same mold and at 14lbs that's a great wheel. If your going for points in a show and you want the Volk/Ings name on your wheels, then by all means go for the $1000/rim.
To each his own.
Ichito240 is offline   Reply With Quote
Wheel Directory: XXR 530 18x8.75 +35 JoeBoxer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 04-02-2015 12:38 PM
Wheel Directory: BBS LM 18x8.0 +50 stoneman155 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 07-08-2013 08:55 PM
Wheel Directory: BBS RE 18x8.0 +50 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-25-2013 09:49 PM
Wheel Directory: ESM 004 18x8.0 +40 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 06-13-2013 03:43 PM
Wheel Directory: Blitz BRW Profile 08 18x8.0 +45 / 18x8.0 +38 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-27-2012 04:34 PM
