Old 07-07-2012, 03:21 PM   #15
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
Originally Posted by ill86 View Post
That is not completely true. I don't have time to type a full reply now. You aren't taking into consideration tire weight, unsprung weight or effective gearing change to a taller tire. I do this for a living.. Not trying to argue.
40 & 45 side wall is not a 5mm change. It's a percentage of aspect ratio..
An 18" tire in the same aspect ratio typicallg weighs more.
Unsprung weight is more because the tire is further away from the hub.
an extra inch of traction? Because of a side wall or diameter change? No. contact patch is the same..
Lots of factors.. You cannot simply sum it up. I do tbis on real race tracks all day lonv.
I'm just debating your comment of saying the handling will get worse, but I'm also not disclosing fully what else is going on with the car. It already has coilovers and will be corner balanced once I decide between the two sets of wheels I'm getting. After that adjustable control arms are the next step. So there's more in my area than just getting nice wheels, but I get your point and my generalization definitely didn't account for that.
As for the measurements, 5mm is based on height measurements done with mounted tires on 18x8 +40 wheels with 225/40/18 tires compared to stock tires. It's actually a gain of 5.95mm of height, and a gain of 2 lbs per wheel with the tire/wheel setup.
denkigrve is offline   Reply With Quote
Old 07-07-2012, 07:55 PM   #16
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
ill86 is offline   Reply With Quote
OptionJDM: Enkei Wheels available! OptionJDM Wheels and Tires 49 11-09-2012 11:08 PM
Enkei Wheels at Island Import Performance | Direct and Authorized Dealer IslandImportPerformance Wheels and Tires 2 07-20-2012 01:06 PM
Wheels like Enkei’s Fujin Staticfrost Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 05-29-2012 10:38 PM
Enkei Symbiont Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 05-26-2012 08:36 PM
Enkei Matte Black RP03 Racing Series wheels! toxicdrift Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 04-22-2012 04:37 PM
