#15 | |
Drives: CRV AWD 5MT
#16 |
Drives: 2005 Toyota Camry
There is a ton of info about rear traction arms and what they do, especially on Nissan RWD forums.
Nissan ran this rear suspension setup for almost 20 years, and just so happens to be cars wildly popular. S13/14/15, Z32, R32/33/34, other JDM RWD chassis. The rear setup on our cars is slightly different, but the basic idea is the same. Most people end up going with adjustable LCA because it's easier to work with. Not ideal, but easier. If you wanted ONLY camber adjustment without affecting toe as much, you'd go with adjustable upper arms, but then you'd find that 1) there's a ball joint, and 2) there's no room to work with. Oh, and too much negative camber in the rear will force you to get adjustable toe arms, as the toe adjustment is maxed out. -alex |
#17 | |
Drives: CRV AWD 5MT
#18 | |
Rear multilink is great, but from a cost perspective it's not the best, especially when your entire company struggles. See: Nissan in 1990s. Our entire suspension is a compromise. Basically it's built to Toyota specs but with recycled Subaru parts whenever possible. -alex |
#19 |
Drives: CRV AWD 5MT
All very true.
Re market demands probably a discussion to be had around the japanese foray into CVTs. |
#20 |
Drives: GT86
I have the Whiteline upper camber bushes. They're a bit of a pita to fit but not too bad. Adjustment is also not too bad with the car up on a ramp but can take a few goes to get right. What I like about them is that as well as allowing you to correct the camber they also take some slop out of the rear of the car.
#21 |
I have the RacerX UCAs and you do need to pop the ball joints out to adjust them and the your adjustment range is about .5 degrees at one time. Mine happen to be adjusted to right at 2 degrees with the car lowered a bit so they work well for me, doubt I'll ever change them from that.
| Cusco LCA, Toe Arms, Trailing Arms | xDBOYx | Brakes, Suspension, Chassis | 10 | 05-23-2015 07:11 PM |
| SPL traction / trailing arms | boomslang | Forced Induction | 2 | 09-17-2014 06:25 PM |
| Stance Trailing and Toe Arms | allanejames | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 05-14-2014 02:15 PM |
