Old 07-25-2016, 06:53 PM   #15
Mazikowski
Drives: 2013 GBS BRZ Limited
Originally Posted by guybo View Post
Most of the time "plowing through a corner" is a driver problem, not a car problem. This car has been proven time and again to be very well balanced in its stock form. Yes, most cars are set up from the factory to be plow trucks, the Toyobaru is a different and unique beast.
Oh, definitely. Those times were totally my fault, coming in too hit and braking too late.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Mazikowski is offline   Reply With Quote
Old 07-25-2016, 09:24 PM   #16
atlbrz
Drives: Hyper Blue BRZ
If your car is nicely balanced, you carry enough speed into the corner to induce some slip angle into your front tires. You than use the throttle to over drive the rear tires and effectively create a small controlled four wheel drift. To much speed and your front slip angle will increase too much and your tires scrub off speed. Apply to much throttle and the rear-end will start coming around on. It is nice when the car is balanced. Getting there can be a challenge.
atlbrz is offline   Reply With Quote
Understeer Solutions? Sway Bars? Gopherboy6956 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 56 07-04-2019 03:49 AM
Handling Setup - Oversteer vs. Understeer DarkSunrise Tracking / Autocross / HPDE / Drifting 58 07-29-2015 09:15 AM
Do pigs understeer? Thrustin Off-Topic Lounge [WARNING: NO POLITICS] 11 05-31-2014 09:42 AM
BRZ stock suspension understeer... what to do? mtimney Tracking / Autocross / HPDE / Drifting 40 07-31-2013 12:48 PM
03/23 Reviews --> No understeer complaints... bloomy116 BRZ First-Gen (2012+) — General Topics 19 03-26-2012 11:06 AM
