#15 | |
Badass Member
Drives: 2014 SWP BRZ Limited
I researched everywhere on how to replace it and it literally tells you to remove everything on the door. Strip it all the way. Even remove the glasses and window lift motor just to get to that door lock mechanism. Luckly, I have experience doing it as I had to help strip my friends FRS for a race car conversion. It just takes a long time and putting them back together is a different story. |
#16 | |
not playing cards
Wouldn't count on it though.
#17 | |
Badass Member
I work for a company that does door lock. I would just find a motor sitting in the office and swap worms if I could. |
#18 | |
Potato Farmer
Drives: #SLOBRZ
That sounds painful, Hopefully the replacements last longer. I was glad it did it just before my warranty ran out.. unlike my water pump, that went a month after it finished..
Something something butter..
www.vic86brzclub.com |
#19 |
Badass Member
@Tcoat @Ultramaroon
I have to revive this thread as I finally did fix it and did investigation. The main culprit is the motor. Grease built up on the commutators that prevents full contact to drive the motor. The worm gear or connections are totally fine. I completely replaced the whole door lock assembly (40 bucks used on EBay). Replacing it was really easy. I just didnt want to do the work of removing the panels, window, and part of the regulator assembly. But I was bored and the car was sitting in the shop. I tried mending the old one but it was impossible to open the door lock housing with out breaking tabs and ruining part of the mechanism inside. I knew I wasn't going to get it back together so I just tore it apart. With my background with motors, I opened it and immediately found the issue. Cleaned the commutator and the motor works fine now but I cannot put it back together. There you have it. If anyone wants to do this, it's easy. 2 years of procrastination didn't help. |
| The Following 3 Users Say Thank You to Kayysonie For This Useful Post: |
#20 |
not playing cards
Oh well, better late than never. Makes perfect sense. Interesting failure mode. Sloppy application during assembly, or design oversight allowing grease to sling in there?
#21 | |
#22 | |
Badass Member
Probably a bad batch or something but not a lot of people get them. |
| The Following User Says Thank You to Kayysonie For This Useful Post: | Ultramaroon (02-20-2018) |
#23 |
Badass Member
Yep exactly. When I ran it first just motor only, the motor didnt run but once I spun it a little it moved.
| The Following User Says Thank You to Kayysonie For This Useful Post: | Tcoat (02-20-2018) |
#24 |
Potato Farmer
Drives: #SLOBRZ
So, 2 years after having mine replaced, they are playing up again..
And I doubt Subi will care about any warranty after i told them to get fucked and trying to screw me over. . I reckon i could rebuild the existing one, but need a spare, just in case..
#25 | |
Drives: 2015 Scion FR-S (Asphalt)
#26 |
Anyone have a part number for the lock assembly?
#27 |
Drives: 2015 BRZ Series.Blue
Just started experiencing this issue :-(
#28 |
Badass Member
| Automatic Door Lock? | LostSalad | Cosmetic Modification (Interior/Exterior/Lighting) | 22 | 01-24-2019 03:52 PM |
| best way to repair this door? | edigeek | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 28 | 08-20-2016 11:05 PM |
| Lock door with fob while car is running? | jhh3000 | BRZ First-Gen (2012+) — General Topics | 2 | 06-05-2014 12:04 AM |
| Door lock issue | BRZ323 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 04-13-2014 10:07 PM |
| Request: Magnetic seat belt lock | funbeatsfast | DIY (Do-It-Yourself) Guides | 3 | 03-14-2013 11:11 PM |
