#15 |
Drives: 2013 WRB Subaru BRZ
My 3D maxspider (sp?) floormats are already torn in the heel part underneath the pedals. It doesn't really look the tear will go all the way to the floor, but I'm not sure. I've only had the mats for about 9 months also. I figured these mats would last a long time, but I guess not
#16 |
Drives: car
@JD001 well remember that your right heel is going to be on the outside as opposed to the interior tunnel, so it's probably the orientation difference that makes it where you don't have problem.
@krayzie Very interesting that the BRZ mats aren't cut the right size. Are there any threads / measurements / pics to confirm this? |
#17 | |
Drives: Subaru BRZ
#18 | |
Drive From Home
Drives: BRZ STI Performance
Easiest way to see is to compare your stock carpets with the FRS ones. The FRS front carpets are much longer wider, and cover right upto the parameter of the flooring, exactly the same cutout as my European BRZ carpets and fit perfectly. The North American BRZ carpets are a tad small in comparison and way too stiff due to the rubber bottom so they don't really sit flush at the edges (not sure if this is the root cause of your issue). I've wrote to SOA already but they don't seem to care. |
| The Following User Says Thank You to krayzie For This Useful Post: | radroach (07-14-2016) |
| BRZ Floor Mats | woode | Cosmetic Modification (Interior/Exterior/Lighting) | 37 | 03-28-2017 04:55 AM |
| FS: OEM FRS Floor Mats | Rontae | Interior Parts (Incl. Lighting) | 1 | 05-05-2015 08:31 PM |
| FS: Scion FR-S Factory Carpeted Floor Mats (Never Used - Full Set of 4 Mats) | Ammunition | Interior Parts (Incl. Lighting) | 1 | 11-14-2014 08:48 PM |
| FR-S Heel Pad FLOOR MATS? | TYPEONE86 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 12-29-2012 07:24 AM |
| No floor mats? | whateatsrabbits | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 08-22-2012 05:35 PM |
