Old 07-07-2016, 02:49 AM   #15
Vivos71
Vivos71's Avatar
Drives: R.S. 2.0
Originally Posted by Mim View Post
Bought a top of the line Pioneer head unit (AVIC-F70DAB)
How is the screen responsiveness/quickness of the menus? I am considering one of the newer, yet less expensive versions.
Vivos71 is offline   Reply With Quote
Old 07-07-2016, 03:34 AM   #16
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
Similar responsiveness to my iPhone 6 so pretty amazing. Carplay issues aside I'm really impressed.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
Old 07-09-2016, 10:02 AM   #17
soundman98
ProCrastinationConsultant
soundman98's Avatar
currently running a pioneer avh-x7800bt flip up unit because i didn't want to give up the cubby hole a single-din opens up.
Old 07-09-2016, 10:10 AM   #18
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Using the car joying JQ123 Android HU. As long as you use an EQ other than built in one, it sounds pretty damn good. Apps seem to work well.
Rican_D is offline   Reply With Quote
Old 07-09-2016, 08:21 PM   #19
Mattstermh
Drives: '13 FR-S A/T - Stock
I'm looking for really high quality sound upgrade but I've never done an audio mod to a car. I'm probably going to have Best Buy do it - not looking to spend an arm and a leg but I have no clue what to get (I use Android w/ a Nexus 5X).
I just care about Bluetooth and crisp beats
Mattstermh is offline   Reply With Quote
Old 07-10-2016, 10:29 AM   #20
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
brz install is easiest ever. Even if you just ghetto twist the wires on the harness it will blow away the oem quality.
I'd at least go to a dedicated audio/security shop. Could maybe have them do some additional improvements.
GeorgeJFrick is offline   Reply With Quote
Old 07-10-2016, 01:31 PM   #21
Mattstermh
Isn't it best to buy the hardware myself and then have them install it?
Old 07-10-2016, 01:57 PM   #22
FNCrazy
Rambling Man
FNCrazy's Avatar
Drives: 2013 FR-S 6MT - In Heaven Now
Yes, except the problem in this case is who "them" is. Best buy etc al. Are notorious for low end gear at not so low end prices. You'd do much better sticking around here, getting higher quality gear for your money, then finding someone to install it.
Sent from my SM-G935V using Tapatalk
FNCrazy is offline   Reply With Quote
Old 07-10-2016, 01:59 PM   #23
FNCrazy
Rambling Man
FNCrazy's Avatar
I'm not sure that made sense... I just woke up. Stick around here for gear tips and have someone better than best buy install it. There.
The Following User Says Thank You to FNCrazy For This Useful Post:
Mattstermh (07-10-2016)
Old 07-19-2016, 03:34 PM   #24
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
if you're gonna have a shop do it why not give some love to a local audio shop instead? chances of finding good/reliable installers is much higher than at a best buy.
anyway here's my stereo that i like to show off every once in awhile. It's hardwired in for audio and power and is running through a single din unit that sits behind it. aftermarket speakers, amp, and sub installed myself. not quite complete, but pretty darn close and super functional.
unfortunately it isn't jailbroken anymore. still waiting on someone to release one for the current verison of ios, but once they do i'll be using this same interface again. also this last picture is the oldest picture of the trim piece i made. it has since been redone multiple times and looks far better now than before. this picture is just to show the potential interface possibilities
phanguy is offline   Reply With Quote
Old 07-22-2016, 04:34 PM   #25
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by radroach View Post
Sony XSPN1BT, bluetooth head unit with phone mount. $150, using a Nexus 5x with it.
It sounds pretty good bluetooth wise, nice and clear. Though heavy amounts of bass don't come across the stock speaker system well, but I haven't messed with the EQ. Features are decent, USB port 1.5Ah charging, Voice button works great for Google Now voice commands. Allows for color customization on the buttons (blue or amber LEDs.) Has a wired microphone.
There are a few gripes, the lever holding the phone in place is flimsy and my phone was flying out, but I modified it with a piece of sugru plastic molding to hold it in place and I'm happy with how it works now. The unit also came in running the demo mode and also had an annoying button beep but fortunately I was able to turn them off. Also the only way to use the menu functions is to use the included remote control.
Also my phone was actually pretty incompatible with it, but I fixed with with an easy hack as well. My Nexus 5x has its power button on the side, so I couldn't turn the screen on with it in the cradle. But I found that I could use an app called Wakeup Touch Nexus which uses the photosensor to detect my hand waving to turn it on. Works great. So be aware that in order to use this kind of head unit that you'd need a front-facing power button, a tap to wake function, or the app I mentioned.
Dude that is pretty sick. Gonna have to look in to that
Old 09-09-2016, 08:42 AM   #26
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I just ordered the Clarion NX706 Head unit. It has an optical output so I can run that to my DSP for a really clean signal.
And like others have said, please go to a local car audio shop instead of Best Buy to purchase/install your equipment if you're not going to do it yourself.
kmbkk is offline   Reply With Quote
Old 09-09-2016, 11:52 AM   #27
XtremeMaC
Drives: Asphalt Grey FR-S
I do not see the point of Android Auto. For me a major reason to switch to Android based HU is so that it won't eat up my phone's battery and that I won't have to mount my phone anywhere.
For the most part I use navigation on my car and for things like music BT works perfectly. I can already install Google Now, Maps, Yelp, etc on the Android HU and once you enter your account info, it's the same as your phone...
Am I missing something?
2013 Asphalt Grey FR-S MT VIN: 7086XX
XtremeMaC is offline   Reply With Quote
Old 09-24-2016, 04:27 AM   #28
DaveB.inVa
Drives: 2016 BRZ Premium
I may be a little odd, but I took what some may consider a step backward.
I wasn't satisfied with the 2016 head unit at all and didn't really like the idea of a touchscreen without steering wheel controls. I have other touchscreen units in my 2007 Ram and 2015 Tacoma, but I have steering wheel controls with them so I could advance through presets, change mode, etc without paying much attention to the screen.
Instead of a touchscreen unit, I opted for a double din Pioneer FH-X830BHS. It has all buttons and knob so I can operate by feel.
Since I have a 2016, I had to buy the 2015 Series Blue dash pieces to get everything to look right. I also had to splice for the amp trigger. The BRZ is small so loss of the backup camera wasn't an issue.
When I bought the head unit, a SiriusXM kit came free with it so I installed it and connected through the factory antenna. I don't subscribe but it was free and the XM free weeks are pretty neat.
Overall, I'm very satisifed with the unit, it sounds great and does what I want.
DaveB.inVa is offline   Reply With Quote
Head unit cover/Stereo Delete 6spd Cosmetic Modification (Interior/Exterior/Lighting) 10 07-19-2016 04:19 AM
Looking for help adding sub and amp to existing 2016 FRS sound system and head unit Sonicp9 Electronics | Audio | NAV | Infotainment 2 02-27-2016 10:24 PM
What mode are you running on your stock stereo TC, XB, XA, Frs Yruyur Electronics | Audio | NAV | Infotainment 9 02-03-2013 01:18 PM
Stock Stereo Head Unit Languages Bonburner Electronics | Audio | NAV | Infotainment 12 08-18-2012 08:41 PM
Base Stereo or Upgraded Head Unit?? rb123 CANADA 22 07-25-2012 01:43 PM
