Old 06-10-2016, 09:39 AM   #15
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Originally Posted by Tor View Post
What toe arm and LCA did you get?
It's probably not the diff bushings, as that can't cause toe change either. The problem must be in the suspension bushings.
Parts shop max LCA
And SPL toe arm w lock outs.
Also as for the driver mod thing. this isn't anything to do with when I launch as its not really bad if I launch the car. Its mainly if I floor it in first, and start spinning. or If I do a burnout. Which these are things I can live with out doing.
Spinning doesn't bother me as it satisfies me and makes me feel like my car has 10000 hp. Its just the hopping that I would be able to live with out.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 06-10-2016, 09:39 AM   #16
nickmerronesucks
Ned flanders
Originally Posted by Yoshoobaroo View Post
A rocking differential can induce wheel hop, the BMW rear ends benefit a lot from differential lock down kits
-Josh
Yes I had the active autowerke brace on my Supercharged M3. helped alot also from what I understand took off a lot of stress on the center diff bolt.
797Performance.com
Old 06-10-2016, 09:46 AM   #17
nickmerronesucks
Ned flanders
was looking into doing these. Saw a friend on facebook posting these and some werid looking brace that I cant find anywhere and say goodbye wheel hop. lol
http://www.whiteline.com.au/product_..._number=W63414
797Performance.com
Old 06-10-2016, 10:34 AM   #18
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Differential brace. Several manufacturers make them for the twins.
Old 06-10-2016, 10:53 AM   #19
nickmerronesucks
Ned flanders
No it went from the lower control arm area to the trailing arm, I think its the cusco one I just found. I don't believe the differential brace works when you are running diff bushing inserts.
797Performance.com
Old 06-10-2016, 11:12 AM   #20
Summerwolf
Panda Trueno
Summerwolf's Avatar
People do it, but it mostly negates the bushing usefulness.
Old 04-28-2022, 10:30 PM   #21
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
This thread ever get sorted?
I know mine is the rear diff bushings. Added some whiteline bits, but the bushings that bolt to the rear of the diff housings are my problem with wheel hop. Added the Whiteline bushing inserts here, and it helped, but it's still there.
People think the tire is doing it, it's not, it's those bushings getting wound up and kicking back. Mine gets in a harmonic sometimes without ever breaking loose if I have to use the clutch too much at parking lot speeds.
Never an issue before I boosted the car. I'm trying to understand if I should try some 70 Durometer bushings from RallySportDirect or try a Cucso brace. Input on either would be helpful.
For reference, I changed engine mounts as well and tried TorqueSolution. They're great, but too much NVH for my commuter. Just swapped out to group N STI mounts from RallySportDirect, NVH gone. More movement you can really feel in the throttle press/ift comparatively. But still much better than stock mounts and no NVH. Now I'm going after the rear end since the inserts aren't a 100% fix. But I really don't want to overshoot like I did with the engine mounts.
I think I saw group N rear diff bushings or STI rear bushings, not sure. Probably a Japan order. I've seen 70 Durometer bushings on Rally site. But that feels too close to the TorqueSolution engine mounts, which were 75 durometer. And I don't want to overshoot again.
jeepmor is offline   Reply With Quote
Old 04-29-2022, 04:42 PM   #22
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Why has nobody mentioned Trailing Arm bushings. The thrust of the wheel goes straight through the trailing arm. Allowing it to move forward and backward.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
The Following User Says Thank You to Westen86 For This Useful Post:
jeepmor (04-30-2022)
Old 04-30-2022, 05:32 PM   #23
jeepmor
I agree, but the deflection of the rear diff mounted bushings is very noticeable. I have an MCA traction mod to go on still. I'll do this before I put more bushings in. It'll lower that trailing arm a bit and may help. Gets good feedback and claims to help with traction too.
Car losing traction in corners Chase1996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 82 03-06-2016 07:50 PM
losing traction? sskillzz12 Engine, Exhaust, Transmission 4 03-24-2015 09:51 PM
Shuddering noise when engaging clutch Lido Issues | Warranty | Recalls / TSB 15 04-11-2014 09:46 PM
Automatic Shuddering when slowing to stop Craig Issues | Warranty | Recalls / TSB 0 11-14-2012 06:40 PM
Lowered Car, Losing traction while getting off drive ways 86_ZN6 Scion FR-S / Toyota 86 GT86 General Forum 54 10-26-2012 10:02 AM
