View Poll Results: Cut out for rear deck break light?
Yes 14 25.45%
No 41 74.55%
Voters: 55. You may not vote on this poll
Old 05-17-2016, 05:09 PM   #15
acetothermus
Drives: Flying in a Blue Dream
Originally Posted by BirdTRD View Post
Naw, black that shit out and get a set of these bad boys!
Perfect! Problem solved!
acetothermus is offline   Reply With Quote
Old 05-17-2016, 05:14 PM   #16
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
I have 5% rear with a cut out, and I highly recommend it.
dhuang is offline   Reply With Quote
The Following 3 Users Say Thank You to dhuang For This Useful Post:
acetothermus (05-17-2016), iamjacob (05-17-2016), Tcoat (05-17-2016)
Old 05-17-2016, 05:21 PM   #17
acetothermus
Do a nice neat job as close as possible to the light and the cut out will look fine.
I'm hoping they can have it over the edge of the light just a bit so that no light bleeds past the cut out into the cab.
The Following User Says Thank You to acetothermus For This Useful Post:
Tcoat (05-17-2016)
Old 05-17-2016, 05:22 PM   #18
acetothermus
Oh man. You just made my day! Thank you so much for posting that pic. That's exactly what I'm hoping they'll do.
Old 05-17-2016, 05:24 PM   #19
Ya that looks fine.
Old 05-17-2016, 05:27 PM   #20
johan
Drives: '14 981CS, '99 NB1
Also, my eyes are EXTREMELY light sensitive. To the point that when it's night and I've got headlights blaring in the back window, it blinds me. My sunglasses are the darkest you can get without being legally blind, and they are still too light causing me to squint in bright light. So blocking as much light as possible is in my opinion worth the cost of me having to be a tad more vigilant at night while driving.
[ame="http://www.amazon.com/Genuine-Subaru-H501SCA100-Auto-Dimming-Compass/dp/B00HRXUIA0"]Amazon.com: Genuine Subaru H501SCA100 Auto-Dimming Mirror Compass: Automotive[/ame]
I added this on my FR-S, works great - love the homelink buttons for opening my garage door too.
johan is offline   Reply With Quote
Old 05-17-2016, 05:31 PM   #21
iamjacob
insert witty quip here
Drives: 2016 Limited BRZ
The only gripe I have with mine is that it only works when the car is on and not a second longer. It really should be on the same circuit as the windows so it stays on long enough to close the garage door after you shut off the motor.
iamjacob is offline   Reply With Quote
The Following User Says Thank You to iamjacob For This Useful Post:
Old 05-17-2016, 05:41 PM   #22
gramicci101
Off Topic
I have 20% on mine with no cutout, and the third brake light is pretty dim. I could have gotten it with a cutout, but I hate how that looks. I'll probably get a fourth brake light at some point.
Also, in Las Vegas 20% is not nearly dark enough. I'm debating going to 5 or 15%.
Old 05-17-2016, 06:04 PM   #23
acetothermus
So very this. It's a pain, but I've learned to live with it.
Old 05-17-2016, 07:49 PM   #24
Rattle
Drives: BRZ soon
If you want to keep the original third brake light and go 5% tint, then id cut a hole for the light output to be good. 5% would be hard for others to see the light output.
Otherwise you could remove the third brake light if you want to not have a cut out, and buy the fourth brake light from Modbargains.
Personally i like the look of the original third light gone and adding the fourth brake light. Although it would depend on how strict the law enforcement is in your area.
Rattle is offline   Reply With Quote
Old 05-17-2016, 09:40 PM   #25
gramicci101
Off Topic
There is also a high-mounted third brake light from a mustang.
http://www.ft86club.com/forums/showthread.php?t=72225
The Following User Says Thank You to gramicci101 For This Useful Post:
acetothermus (05-18-2016)
Old 05-18-2016, 12:55 PM   #26
acetothermus
So I dropped the car off and the installer came out to do a walk around and asked me about doing the cut out. He mentioned it was totally possible and he has done it in several cars, but doesn't recommend it. He said the eye is instantly drawn to it and no mater how good the overlap is there will always be light bleed around it. Every time he did it for someone, within a max of two days they were back having the window redone. So It looks like I'll go with the 4th break light and maybe even wire in the this to it just to make it a little more visible.
Thanks to everyone for your input. I'll update the first post with pics once I get her back.
Old 05-18-2016, 03:06 PM   #27
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
If you are going with the 4th brake light option, here's a few things to look over. I just did the 4th brake light mod to the OEM light assembly and a week later installed the Valenti 4th brake with a mod to not have it blink while braking. Enjoy!
http://www.ft86club.com/forums/showp...ostcount=14245
http://www.ft86club.com/forums/showthread.php?t=105833
BirdTRD is offline   Reply With Quote
Old 05-18-2016, 05:07 PM   #28
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
for me : 20 rear, 35 side, 55 front
FR-Sky is offline   Reply With Quote
How-To: Remove Rear Deck & Third Brake Light Moshpit37 DIY (Do-It-Yourself) Guides 63 08-01-2020 09:48 PM
WTB: REAR window top Brake Light (just top half with leds) or full rear deck Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 1 08-31-2013 02:23 PM
VIRGINIA drivers - is your tint cut-out for the rear deck brake light? shirker Mid-Atlantic 7 06-07-2013 07:18 PM
