Old 05-17-2016, 02:15 PM   #15
That's it? I had pictures of huge clouds of smoke following you down the road. Mine has looked like that since day one. I think it is just the really rich startup mix that the stock tune uses and isn't oil at all. If it goes right away after the car has warmed up and it isn't happening when you drive or sit and idle I wouldn't sweat it.
humfrz (05-17-2016), jawn (05-17-2016), strat61caster (05-19-2016)
Old 05-17-2016, 02:49 PM   #16
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Yeah, that's likely just water vapor and the rich startup mix.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
Tcoat (05-17-2016)
Old 05-17-2016, 02:58 PM   #17
HunterGreene
Hail Magnet
HunterGreene's Avatar
After reading this thread, I feel I have seen enough to render my opinion:
Totalled.
/sarcasm
Also, good choice of taillights.
It has priests in it?
Old 05-17-2016, 03:36 PM   #18
stevesnj
stevesnj's Avatar
Looks normal, Like I said it's a rich start up mix and if it's chilly enough it's condensation built up inside.
My 2016 Build thread
Old 05-17-2016, 10:12 PM   #19
humfrz
Originally Posted by wyatt263 View Post
Smoke is definitely coming OUT of the tailpipe when starting, this is not oil burning off of the exhaust. Here is a short video I took this morning after letting it sit for about 12 hours.
Yesterday this was far worse and smoked immediately after start up with no throttle applied.
I reckon, compared to your car, mine is about to blow up and/or needs a ring job .......
humfrz
Old 05-17-2016, 10:26 PM   #20
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Water vapor! Perfectly normal for any car on a cold start.
billwot is offline   Reply With Quote
Old 05-17-2016, 11:13 PM   #21
wyatt263
wyatt263's Avatar
Drives: 2013 Scion FRS, 1985 Toyota Supra
I am not going to worry about it for now, I am not convinced that the cold start on Monday is water vapor, due to the fact it was 80° and no humidity. The smoke was blue and black, not whitish in humfrz video. The smoke also lingered and moved with the wind and did not dissipate whatsoever, but for now, I won't worry. Next time my car sits longer and it's hot and sunny outside I'll take a better video. I am convinced that there is an issue.
wyatt263 is offline   Reply With Quote
Old 05-18-2016, 01:35 AM   #22
humfrz
Well, if you're not convinced your car is "normal" and just burning rich on startup, yes, by all means take and post another video.
Might I suggest you also take a video of a warm startup for comparison purposes.
It would seem to me, that if a car is "burning" oil (getting past the rings or blow-by from the crankcase), that it would be more noticeable coming out of a warm engine........
humfrz
Old 05-18-2016, 07:11 AM   #23
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
That didn't look all that bad to me. what did the smoke smell like and do you have any wet oily residue on the inside of the exhaust tips? Is it a dry black sooty residue?
Hyper Blue fender garnish on a Series Blue BRZ - with Pictures chamourian Cosmetic Modification (Interior/Exterior/Lighting) 20 05-13-2016 05:33 PM
2015 BRZ Series.Blue STI Turbo 5k miles Manual Fully Loaded + blue LED conversion bren5279 Cars for Sale/Trade 40 04-21-2015 11:32 PM
Trying to find a Blue series.Blue (I think I totaled my baby) Hyper4mance2k BRZ First-Gen (2012+) — General Topics 32 04-18-2015 01:36 PM
A little blue smoke on startup PollosHermanos Issues | Warranty | Recalls / TSB 12 11-16-2014 10:17 PM
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! Speed Element Wheels and Tires 151 09-26-2013 05:56 PM
