Old 05-27-2016, 04:49 PM   #15
zenex
Drives: 2014 Boosted Subaru BRZ Limited
Possibly then, might switch to 1000cc
Sent from my SM-N920V using Tapatalk
zenex is offline   Reply With Quote
Old 05-27-2016, 04:49 PM   #16
zenex
What gas were you running?
Old 05-27-2016, 04:59 PM   #17
-Phil
Drives: Rb25 neo brz
e85, and for the transmission we ended up going with PAR, however we are still waiting on getting the gears to us. the car currently see's heavy track use at 400 WHP and the transmission has no issues at this power.
-Phil is offline   Reply With Quote
The Following User Says Thank You to -Phil For This Useful Post:
SoCal80six (05-29-2016)
Old 05-27-2016, 05:04 PM   #18
zenex
Ah, okay. I'll see how the power feels with the 850cc and upgrade in the future if needed. As far as the transmission I'm weighing different options, how much did par run?
Old 05-31-2016, 06:29 PM   #19
-Phil
Par ended up being over 4k plus shipping and we are still waiting
Old 08-29-2016, 06:33 PM   #20
zenex
Running and driving just to finish first 100 miles break in before I can get her back
Old 10-08-2016, 04:33 PM   #21
zenex
Still haven't gotten the car back but it's having cold start issues threw p058a and p058b codes which are saying it's not achieving target idle on cold starts. Don't know what the issue is as of yet. Swapped throttle body maf and map and problem isn't as bad but still there wondering if my injen cold air intake I have on it for breakin is the issue.
Old 10-09-2016, 12:35 AM   #22
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Why may i ask are you using NA as your breaking in method? I dont think those low comp pistons like the stock intake. It might idle hunt.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 10-09-2016, 01:08 AM   #23
zenex
It's what the shop I have it at recommends 1000 miles na not going above 4k rpm. Plus I don't have the cash flow to finish buying all the stuff for the turbo gunna get it back then finish buying the stuff and throw it on and tune it once it's done
Old 10-09-2016, 01:09 AM   #24
zenex
It runs perfect hot. No issues idle hunting it's just cold start that's giving us issues
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 05:00 PM
SWP's 13' BRZ Build Thread SWP BRZ Member's Car Journals 2 01-16-2015 02:23 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 08:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 08:34 PM
