Old 04-28-2016, 12:45 PM   #15
TheGuyWithTheFireStorm
Drives: FireStorm MT FRS
I follow a guy on IG who has this on his twin, not sure if he's on the forum tho.. Assuming his car was the guinea pig for injen.
TheGuyWithTheFireStorm is offline   Reply With Quote
The Following User Says Thank You to TheGuyWithTheFireStorm For This Useful Post:
MisterSheep (04-28-2016)
Old 04-28-2016, 04:13 PM   #16
G-awesome
Drives: 2015 Firestorm Scion FRS
looks intriguing but im pretty sure the dyno numbers are over inflated. I'm sure the snorkel design will suck in so much water and flood the engine when it rains in Vancouver.
G-awesome is offline   Reply With Quote
Old 05-05-2016, 02:46 PM   #17
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
can we get someone to actually install these & post a real review?.......XD
Always want a ram air intake.....without paying 1k premium to import one from the land of rising sun. (one that actually give you gains..)
Old 05-25-2016, 09:54 AM   #18
hypebrz
IG: @HypeBRZ
hypebrz's Avatar
Drives: Series.Hyperblue BRZ
Anyone got updates on this?
hypebrz is offline   Reply With Quote
Old 05-29-2016, 04:54 AM   #19
Ry.ruzn
Ry.ruzn's Avatar
I Installed it on my brz coming from their SRI. Install was a PITA, takes way to much space in the engine bay and sounds exactly the same as the SRI. Snorkel that hangs from behind the bumper does hold water in it and if your conscious of it swallowing water into your engine I definitely wouldn't go this route. With that being said, Throttle response does feel better with a pleasant sound when you step on it + shift gears.
Ry.ruzn is offline   Reply With Quote
The Following 5 Users Say Thank You to Ry.ruzn For This Useful Post:
G-awesome (05-30-2016), hypebrz (05-30-2016), Hyper4mance2k (06-03-2016), raven1231 (05-31-2016), SuperTom (03-28-2022)
Old 05-30-2016, 01:11 AM   #20
G-awesome
Planning to dyno the car to see how much more hp/tq it makes?
Old 05-30-2016, 10:29 AM   #21
Ry.ruzn
Ry.ruzn's Avatar
Yes,
unfortunately I don't have a stock run to compare too after wards. I will most likely do it in a month or so as I am also looking at getting headers,front pipe and overripe. I have a custom tune from Ft86 but that's only the exhaust and intake. I don't know the numbers it's pushing now.
Does anybody have thoughts on the Gruppe-s Headers vs the Tomei? I would go with the same brand for the front and overripe as I don't like mixing.
Sorry I'll create a thread for that question else where, don't want to jack the point of this thread.
Old 05-30-2016, 02:00 PM   #22
drew_kar
drew_kar's Avatar
Drives: WRB Brz / SR S14
Yes,
They are almost identical in terms of build quality and design.
Sent from my Nexus 5X using Tapatalk
drew_kar is offline   Reply With Quote
The Following 2 Users Say Thank You to drew_kar For This Useful Post:
raven1231 (05-31-2016), Ry.ruzn (05-30-2016)
Old 05-31-2016, 03:04 AM   #23
Vivos71
Vivos71's Avatar
Drives: R.S. 2.0
Would drilling small holes in the bottom of the scoop fix any of the water issues, or would that potentially muck up the efficiency of the intake?
Vivos71 is offline   Reply With Quote
Old 05-31-2016, 09:29 AM   #24
Ry.ruzn
Ry.ruzn's Avatar
Most likely will ruin the efficiency as you will then have air flow pressure pushing and escaping through the drilled holes. I think....
Old 05-31-2016, 09:51 AM   #25
raven1231
I think it looks damn good installed. Not $400 good but still good nonetheless!
Old 05-31-2016, 05:03 PM   #26
Ry.ruzn
Ry.ruzn's Avatar
Haha. It does, but I prefer a clean spacious engine bay. The SRI gave it plenty of room to breath and made other parts of the engine easily accessible. I was thinking of leaving the included air scoop and adding the SRI to see how it would perform. Changing the filter on this thing is also a Pita along with getting the snorkel to fit right on the manifold. Once I dyno I'll see if there is a major difference between the above stated setups.
The Following User Says Thank You to Ry.ruzn For This Useful Post:
Old 06-03-2016, 09:17 PM   #27
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Can you post some more pictures of it? How close it is to the oil filter, etc. Just closer up, overhead shots of the engine bay. Thanks!
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 07-05-2016, 06:43 PM   #28
swarb
15hp bump. Want to see if power gains are as claimed.
Injen intake... Brahsbrah Engine, Exhaust, Transmission 22 04-20-2014 02:16 PM
FS: Injen Air Intake ozne99 Engine, Exhaust, Bolt-Ons 0 01-13-2014 12:05 AM
FS in MA: Injen intake Jesse Engine, Exhaust, Bolt-Ons 4 07-02-2013 10:00 PM
FS: Injen intake mike123mdc Engine, Exhaust, Bolt-Ons 2 07-01-2013 08:56 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 02:31 PM
