Old 04-26-2016, 01:15 AM   #15
funwheeldrive
Is this system overkill for someone who will only track their car a couple times a year?
Old 04-26-2016, 02:27 AM   #16
TkTk
TkTk's Avatar
Drives: 2014 TRD GT86 CUP, 2014 991 GT3
10AN Oil Cooler Lines
Originally Posted by Jackson Racing View Post
-10AN Oil Cooler Lines
- Pre-Assembled at Jackson Racing
- Aeroquip OE Quality Oil Hose
I am worried about that part.
I had a massive leak with perrin oil cooler using these lines.
Is it it possible to to upgrade them ?
TkTk is offline   Reply With Quote
Old 04-26-2016, 03:55 AM   #17
TorqueMan777
TorqueMan777's Avatar
Drives: 13 BRZ, 18 STI
How does the oil cooling capacity compare to the normal Jackson racing air oil cooler?
Racecar spelled backwards is racecaR, because RacecaR
TorqueMan777 is offline   Reply With Quote
Old 04-26-2016, 04:19 AM   #18
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Good news.
Can it in a way or another replace both engine and JRSC oil coolers ?
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 04-26-2016, 01:50 PM   #19
Originally Posted by MaximeT View Post
Good news.
Yes.
MaximeT (04-26-2016), Tristor (03-27-2018)
Old 04-26-2016, 01:56 PM   #20
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
any install pics? Curious to see the layout.
Jyn is offline   Reply With Quote
The Following User Says Thank You to Jyn For This Useful Post:
nickmerronesucks (04-26-2016)
Old 04-26-2016, 02:17 PM   #21
OkieSnuffBox
Drives: '23 BRZ Limited
That looks like abrasion damage to the hose from rubbing against those brake ducts.
If that's the case, it isn't the fault of the hose.
The Following 5 Users Say Thank You to OkieSnuffBox For This Useful Post:
CSG Mike (04-26-2016), Freeman (04-26-2016), nickmerronesucks (04-26-2016), TkTk (04-26-2016), Tristor (03-27-2018)
Old 04-26-2016, 03:47 PM   #22
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
Originally Posted by churchx View Post
This sounds to me better then separate rad ones, at least those with lower mounted oil rad, crash safety wise. I guess, only con might be higher cost, but to get something better one must also pay for that. IIRC there already were such rads with integrated oil cooler (hmm .. was it by Skunk2?), but again iirc there were some fitment issues, not exactly true plug & play ..
Ours is the only complete system, and is the only one that does not require cutting or bending of anything. This is a 100% plug and play system.
Jackson Racing is offline   Reply With Quote
Old 04-26-2016, 03:57 PM   #23
Jackson Racing
Drives: JR FR-S,
Not at all! The Track Engine Oil Cooler may be overkill for you, but the Dual Radiator/Oil Cooler is perfect for the guy who likes spirited driving, but also likes track days. It will handle both driving styles with ease.
The Following 2 Users Say Thank You to Jackson Racing For This Useful Post:
CxG (01-10-2018), Tristor (03-27-2018)
Old 04-26-2016, 03:58 PM   #24
Jackson Racing
Drives: JR FR-S,
That looks like rubbing was the issue, not the line itself.
The Following 3 Users Say Thank You to Jackson Racing For This Useful Post:
Joveen (03-15-2019), nickmerronesucks (04-27-2016), Tristor (03-27-2018)
Old 04-26-2016, 04:24 PM   #25
churchx
churchx's Avatar
Drives: 2014 GT86
About the only thing i personally would be careful with, is how well thermostat works in cold winter weather, as after all, mine is mostly daily driven all year, including temps of -25C. But i guess, if there would have been any problems with thermostats of JR's oil rad kits, it would be reported already about older separate oil rad kit, hence probably my worries are groundless, and so far this kit looks very likely to get in future purchase list.
Old 04-26-2016, 04:28 PM   #26
OkieSnuffBox
Any pictures of it installed?
I like the idea of not having to remove the bumper, getting an oil cooler and also increasing the cooling threshold of the coolant as well.
Seems like an all-around win for all but the most hardcore track guys.
Old 04-26-2016, 04:43 PM   #27
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by mav1178 View Post
This part needs more data.
Does it increase warmup times or decrease warmup times? The Cusco/OEM-type liquid-to-oil cooler decreases warmup times, however with an increase in radiator size & cooling area I see an increase in warmup times more in line with external oil coolers.
Quoting for visibility.
-alex
Old 04-26-2016, 04:49 PM   #28
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Gorgeous part and designs.
I'd like to see some temp graphs of oil and coolant independently, as well as installation pictures to see how the lines are routed.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler Jackson Racing Engine, Exhaust, Bolt-Ons 0 04-25-2016 06:35 PM
Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. OkieSnuffBox Engine, Exhaust, Bolt-Ons 5 01-12-2016 12:26 PM
Jackson Racing Supercharger and JR Oil Cooler bobsacamenoh Engine, Exhaust, Bolt-Ons 20 12-12-2014 03:00 AM
Jackson Racing oil cooler for NA vs FI ayau Engine, Exhaust, Transmission 1 05-29-2014 12:04 PM
