Old 04-24-2016, 09:24 PM   #15
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Cool
That sucks. Good to hear you survived! Since you had the Monogram spec are you going to get a BRZ as a replacement? If my car should ever suffer a violent death, I would probably go with the BRZ.
My current build is 'The Birth of 86'
I hope the day never comes that I have to rename the thread to 'The Death of 86' RIP
If you can afford it, you should get an Audi R8! This would be the next best thing!
I'm sure better days are ahead of you in your driving future!
Peace and should your 86 rest in peace.
Chad86 is offline   Reply With Quote
The Following User Says Thank You to Chad86 For This Useful Post:
CO777DAL (04-30-2016)
Old 04-24-2016, 09:33 PM   #16
CatScan
Originally Posted by ToySub1946 View Post
Just a suggestion... Something made in Modena.
Which would have been totally submerged in the same conditions.
CatScan is offline   Reply With Quote
Old 04-24-2016, 09:35 PM   #17
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
That has nothing to do with what toysub was suggesting.
Old 04-24-2016, 10:14 PM   #18
extrashaky
Drives: 2014 BRZ Limited
Sorry about the car. It happens.
That sucks. Where did four feet of water come from in seconds?
Sounds to me as if the water was already there and OP drove into it. And before anybody criticizes, people drive into floods all the time because they can't actually see that the road is flooded, especially when it's dark or raining hard. One minute you're driving along. Then you're floating. Or sinking. Yeah, sometimes people try to cross when they shouldn't, but a lot (if not most) of these water rescues in Texas were people who got into the water before they realized what was happening.
When I lived in New Orleans, it was a regular thing for people to drive into floods and hydrolock their motors. What happened in Houston, NOLA people just consider Tuesday. I always took the Jeep out if I had no choice but to drive when weather was bad, because I knew the BRZ was at greater risk. Luckily I lived on a street that was a few feet higher than the surrounding blocks, and the vacuum trucks had recently cleaned our sewers.
The Following User Says Thank You to extrashaky For This Useful Post:
Tcoat (04-24-2016)
Old 04-24-2016, 10:32 PM   #19
Ultramaroon
not playing cards
Ultramaroon's Avatar
Buy it back, disassemble it, dry it out, put it back together, and drive it like nothing happened.
Old 04-25-2016, 07:33 AM   #20
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
370Z time!
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
Old 04-25-2016, 09:23 AM   #21
babydriver
Hit the road and I'm gone
babydriver's Avatar
Concrete. Dallas. Springtime in Texas. Sudden torrential rains. A bad combination. Hopefully your insurance company will cover most of the cost of replacement and you'll have a speedy recovery.
It was nothing like your situation, but I tried to cross a "low water" crossing near Austin a few months ago with only about an inch of fast-flowing creek water over the road. I distinctly felt the car begin to drift with the stream. Got through fine, but it scared the crap out of me. These cars are just too low to handle any amount of ponded or flowing water.
Slip, slidin' away.
The Following 2 Users Say Thank You to babydriver For This Useful Post:
CO777DAL (04-30-2016), Tcoat (04-25-2016)
Old 04-25-2016, 10:18 AM   #22
rookie
rookie's Avatar
Drives: 1991 Formula Red NSX
Sucks to hear about the car, at least you can swim and you're living to drive another day.
rookie is offline   Reply With Quote
The Following User Says Thank You to rookie For This Useful Post:
Old 04-25-2016, 12:25 PM   #23
extrashaky
It's not just these cars. Even the brodozers will float right off the road in a few inches of water if it's moving fast enough.
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
Tcoat (04-25-2016), Ultramaroon (04-25-2016)
Old 04-25-2016, 12:54 PM   #24
Scir16v
Drives: 240sx, 2013 frs
sell the headlights?
Scir16v is offline   Reply With Quote
Old 04-25-2016, 02:46 PM   #25
FRSBRZGT86FAN
I know you may be joking. But I had a friend with a 350z that was salvaged from a flood and it's built for track use with BBK, exhaust intake and tune. But he had small electrical issues, that would end up costing him quite a bit to finally get sorted out, it's a fun car to drive when it works. When it rains the stereo loses power or the car stalls it's hilarious, and at night even after replacing the entire headlight assembly the exterior lights and dash clusters will cut in and out. All of it was tied back to an ecu and wiring harness needing to be replaced which was quite expensive to get replaced, almost $3000. After that it drove like new, however it occasionally smells a bit musty and although most of the interior is new there are areas underneath the carpeting that could use an alcohol bath which is what he's doing and dynamat placement, also parts of the car rattle and squeak more than the FR-S because it's needed to be taken apart so much.
Bottom line, it's only worth it if it's not your daily driver
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
ToySub1946 (04-25-2016)
Old 04-25-2016, 03:30 PM   #26
extrashaky
Originally Posted by FRSBRZGT86FAN View Post
I know you may be joking. But I had a friend with a 350z that was salvaged from a flood and it's built for track use with BBK, exhaust intake and tune. But he had small electrical issues, that would end up costing him quite a bit to finally get sorted out, it's a fun car to drive when it works. When it rains the stereo loses power or the car stalls it's hilarious, and at night even after replacing the entire headlight assembly the exterior lights and dash clusters will cut in and out. All of it was tied back to an ecu and wiring harness needing to be replaced which is quite expensive to get replaced. After that it drove like new
This is what I was thinking. A flood-salvaged car can be a nightmare. Better just to let it go and let insurance help get another one.
Old 04-25-2016, 04:18 PM   #27
Ultramaroon
not playing cards
Nope, disagree. Totally different scenario if you get to it right away and are thorough. You have a golden opportunity if you play your cards right.
Old 04-25-2016, 06:02 PM   #28
mazeroni
Drives: 2013 Scion FR-S Series 10
According to Weather.com
Six inches of flowing water can knock a person off their feet.
  • Water flowing at 7 mph has the equivalent force per unit area as air blowing at EF5 tornado wind speeds.
  • Water moving at 25 mph has the pressure equivalent of wind blowing at 790 mph, faster than the speed of sound.
Add to that how low the car is and yea, your car becomes a canoe before you realize what happened.
mazeroni is offline   Reply With Quote
The Following 4 Users Say Thank You to mazeroni For This Useful Post:
86geek (04-27-2016), sam69 (04-25-2016), Tcoat (04-25-2016), Ultramaroon (04-25-2016)
Thinking about moving to Dallas (area), but concerned about floods/hail Anal0g Southwest 11 05-03-2016 04:43 PM
New Owner, 2014 Monogram Ultramarine FR-S Dallas CO777DAL Scion FR-S / Toyota 86 GT86 General Forum 20 05-11-2014 10:16 PM
New Ultramarine Monogram Here! nwolsky Scion FR-S / Toyota 86 GT86 General Forum 15 04-29-2014 06:23 PM
A casualty of the Boulder floods stugray BRZ First-Gen (2012+) — General Topics 47 10-02-2013 07:35 PM
