Old 04-25-2016, 05:40 PM   #15
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by travisb View Post
I have an updated log from today. I was able to get the sensors threaded nicely into the header. Hopefully it will stay that way.
Old log:
http://datazap.me/u/travis23832/1-o2...zoom=3184-4008
New log:
http://datazap.me/u/travis23832/2016...zoom=2679-2744
This is already zoomed in to a 3rd gear pull. For some reason I had some data drops where everything set to zero. I noticed one time when I glanced at the OFT the screen flickered off and on real quick. Maybe the cable was a little loose.
Anyway, this log looks better to me. But I am definitely not an expert. Let me know what you think.
Edit - I also logged the wideband AFR this time and it stayed at 18 the entire time.
Thanks!
That looks much better, do one more aggressive 1000 rpm to 7000 rpm datalog with constant pulls, you IAMs are fine so knock isn't effecting the motor also your commanded afr and AFR match much better. The problem is I couldn't see much as you were for the most part below 4000 rpm
P0462 - Fuel Level Sensor TurboBRZ Issues | Warranty | Recalls / TSB 20 05-13-2019 08:04 PM
Fuel pump and speed sensor Tt3Sheppard Issues | Warranty | Recalls / TSB 28 04-20-2017 01:54 PM
Beta Testers Wanted- Fuel Pressure Sensor GSpeed Tracking / Autocross / HPDE / Drifting 5 08-16-2015 04:03 PM
Brand new 4 Bar MAF Sensor & 700cc Deatschwerks Fuel Injectors deedz Engine, Exhaust, Bolt-Ons 7 03-26-2015 12:21 AM
Fuel Lid Tight or Loose? JiB Issues | Warranty | Recalls / TSB 18 09-20-2012 12:50 PM
