Old 03-25-2016, 10:38 PM   #15
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Originally Posted by ToySub1946 View Post
See if it will buff out lst.
If not, on a 2016, surely a warranty claim...Talk with your service writer very nicely. If they say no, gradually get more insistent. Even if it was your fault, still a warranty claim.
LOL. You should see what's under his hood.
jawn is offline   Reply With Quote
The Following 2 Users Say Thank You to jawn For This Useful Post:
Rifle (03-25-2016), Ultramaroon (03-25-2016)
Old 03-25-2016, 11:03 PM   #16
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Are we friends on Facebook? Let me send you the video of the axle issue. I am not good with who is who in the forums.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 03-25-2016, 11:55 PM   #17
tCsonfrs
Drives: 10 Series FR-S #207
See if it will buff out lst. (Stock answer)
If not, on a 2016, surely a warranty claim...Talk with your service writer very nicely. If they say no, gradually get more insistent. Even if it was your fault, still a warranty claim...unless of course you've done major mods to the power train already.
Oh, I see now, looking at your posts....seems you've added something under the hood of the car....well, still worth a try for warranty.
He has a supercharger, I'd love to see a dealership warranty that.....they won't if they want to keep their franchise.
tCsonfrs is offline   Reply With Quote
The Following 2 Users Say Thank You to tCsonfrs For This Useful Post:
FRSBRZGT86FAN (03-29-2016), Tcoat (03-26-2016)
Old 03-26-2016, 12:31 AM   #18
Rifle
Rifle's Avatar
Thinking it might be axle.
Anyone have a guide to replace them/tips/plan of attack?
@Tcoat / @jawn
295WHP/220TQ
Old 03-26-2016, 12:37 AM   #19
@Tcoat / @jawn
Axle? Doubt it. If there is nothing then you are not getting power to the diff. Does it change tones when you shift and just not move? If an axle the diff should scream like a banshee if it is being powered. Besides the odds against having both axles go at the precisely the same moment are incredible.
Cole (03-26-2016), Ehokana (03-27-2016)
Old 03-26-2016, 01:25 AM   #20
Rifle
Rifle's Avatar
I did think it was the trans letting go so I had it in 6th and revved it up and the rear end did squeal, now that you mention it. I'll try it again tomorrow, but in first. Just give it some gas? Wheels won't move at all.
295WHP/220TQ
Old 03-26-2016, 02:23 AM   #21
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
Late night guess...Quite possibly wrong....but the inner cv joint could easily break on just one axle. The inner cv joint most always being the weaker of the cv joints.
Edit: 11:48pm PDT....after reading this about helical and Torsen differentials:
"Locking on throttle but requires both wheels to be on the ground"... from here:
http://www.trak-life.com/basic-intro...erentials-lsd/
So if one axle or cv joint is broken, it's as if the wheel/tire on that side of the car is 'off the ground'
And if the inner cv joint broke, chances are real good... it also tore open that axle boot (rubber).
ToySub1946 is offline   Reply With Quote
Old 03-26-2016, 02:40 AM   #22
Rifle
Rifle's Avatar
That was my thought. And per several different shops in the area and friends who broke axles, if one breaks the car is dead to the water. I'll check it in the morning.
295WHP/220TQ
Old 03-26-2016, 03:27 AM   #23
ToySub1946
ToySub1946's Avatar
"Thinking it might be axle.
Anyone have a guide to replace them/tips/plan of attack?"
Best to check with others in the suspension section of this forum... if axle needs replacement. Not sure, me, what minimal parts of rear suspension need to come off to get outer end of an axle out. Surely most anyone would need at least a 1/2" air impact wrench with proper socket to easily get the axle nut off end of axle. The inner cv joint would surely just pop out of diff with a pry bar. It's typically held in with an exterior snap ring.
Inner cv joint may be available separately, as a part, rather than purchasing entire axle assembly ??
Pics of rear end suspension >within< this older online section of Edmunds:
http://www.edmunds.com/car-reviews/t...alkaround.html
Old 03-26-2016, 03:15 PM   #24
Rifle
Rifle's Avatar
Turns out it was the axle. Driver side. Just picked up a new one from @Pure Automotive and will be putting it back on shortly!
Thanks to everyone who helped!
295WHP/220TQ
The Following User Says Thank You to Rifle For This Useful Post:
humfrz (03-26-2016)
Old 03-28-2016, 10:20 PM   #25
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
If you can't get the car in the air, arrange a mirror that let's you see the drive shaft. Put it in 5th start the engine and release the clutch. If the drive shaft spins and the wheels don't it's in the rear end. If the DS doesn't spin it's the clutch.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 03-29-2016, 12:19 AM   #26
humfrz
I think he already figured it out; it was a broken axle ...... (post #24) ......
humfrz
Capt Spaulding (03-29-2016)
Old 03-29-2016, 12:21 AM   #27
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
How dafuq you already break an axle?
Ugh I'm probably next.
As a side note, I hope they didn't cut corners for 2016's axles... I mean I know they're shitty in the first place but that was stupid fast dude.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 03-29-2016, 12:36 AM   #28
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Thats exactly how it's removed it literally can be pryed off and on the rear diff
You should replace both with DS ones so its safe up to 600 hp
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Rifle (03-29-2016)
Stiff to engage 1st/reverse from a stop after clutch install mhiscott Engine, Exhaust, Transmission 94 07-19-2020 07:11 PM
Automatic transmission hard parking engage and disengage nos145 Issues | Warranty | Recalls / TSB 21 09-18-2015 07:30 PM
Automatic Transmission Kick/Choke when shifting gears Tech Gremlin Engine, Exhaust, Transmission 13 06-16-2015 01:54 AM
clutch won't fully engage/8000 miles small dent stockscionfrs Scion FR-S / Toyota 86 GT86 General Forum 2 10-14-2014 11:06 AM
Anybody change rear gears or trans gears yet? ramosryan Scion FR-S / Toyota 86 GT86 General Forum 2 06-13-2014 12:48 AM
