#15 |
Hot Lava 6MT
Drives: Hot Lava FR-S
#16 |
Drives: none
Most factory turbo cars get around this by having the PCV vent before the compressor inlet so the valve never sees boost, only atmospheric pressure or vacuum. Many people still install catch cans to avoid sucking oil into the turbo and ultimately coating the intercooler with oil. It's possible to install a catch can that does not vent to atmosphere though. That's what I did on my MR2.
-Matt |
#17 |
Drives: Sterling BRZ Ltd
The problem is not the material of the valve, plastic, metal, solid gold. The problem is the circuit was never intended to see positive pressure. Its not rocket science but it needs to be rearranged for boost.
Drilled out stock piece, no plastic ![]() Plunger is metal, sticks to a magnet just fine
#18 |
If people are paying for a "metal upgrade" what can I sell this High Flow Fully Ported valve for?
#19 |
Drives: 2013 brz limited edition
Where is this pcv located?
Sent from my SM-N920P using Tapatalk |
#20 | |
Drives: 2015 CWP Limited BRZ
The passenger side hose on the intake manifold cover, follow it down and on the block is the factory PCV.
addictedcollectibles.r/My IG
'86 E30 (Project) 'VARIS Widebody http://www.ft86club.com/forums/showthread.php?t=103676 |
#21 |
Drives: FRS, Supra, Colorado D, GLC63
#22 |
So leave the stock valve in place and run the Boomba inline with it? Also thanks!
#23 |
#24 | |
Glorious BRZ Master Race
Drives: Subaru Libird
#25 |
Got a few private messages about this. Confirming part number 11810AA141 fit when I installed it.
#26 |
Drives: White GTS then Black GTS
#27 |
Drives: 18 BRZ tS, 27 GRMN 86
#28 |
You guys should just consider just modifying the PCV system so it's the same as on a WRX/STi. VTA is going to create unwanted crankcase pressure vs vacuum. I definitely recommend managing the blow-by with a can or AOS to scrub clean before going back into the engine. Many more benefits to running a closed loop system.
Nice thing about the FA is the internal baffling is pretty good. The venting capacity could be better (and changing some parts can help that), but it spews WAY less than an EJ engine! |
| FS: Fumoto Valve | jvenetto | Engine, Exhaust, Bolt-Ons | 6 | 10-01-2015 07:16 AM |
| PCV valve leaking? | jamesm | Forced Induction | 24 | 12-25-2014 06:38 PM |
| Heart valve replacement surgery | mike the snake | Off-Topic Lounge [WARNING: NO POLITICS] | 94 | 09-17-2014 01:45 PM |
| Exhaust Cut Off Valve | beagoodruslan | Engine, Exhaust, Transmission | 2 | 01-01-2014 01:47 AM |
