Old 03-30-2016, 08:45 PM   #15
HLHachiRoku
Drives: 2015 HL FR-S
Originally Posted by renfield90 View Post
Not sure if Costco is a top tier fuel, but I kinda doubt it. They may not even use the same supplier every time since their goal is to get the absolute cheapest price possible, so you could have decent quality fuel one day and crap the next.
I fill up primarily with quik trip 91 and I've been pleased with it. Recently autocrossed the car and did not see any significant knock. We'll see what happens when things get much warmer though.
I understand wanting the best price when driving so much but I'd personally rather not detonate. In my experience quik trip is typically the best priced top tier fuel in Phoenix.
Similar setup as you: JDL UEL, stage 2 tune.
Ohh kewl, I did another "dyno" run today. 3rd gear pull, into 4th. 3rd looked fine but 4th had some 1.3 flkc =o. http://www.datazap.me/u/hlhachiroku/...zoom=1949-2217 Have you done any fiddling with your tune at all? Do you have any logs I could look at? I was going to start messing with mine this friday/weekend add that JDL map Shiv posted to, maybe get some better results, haha. I want to upgrade my midpipe too =\ Was looking at the GodSpeed one(change my catback from what I have), from the OP back, only a few hundred bucks. Might be much louder then I currently have tho. Love that rumble that I have now, so deep.
HLHachiRoku is offline   Reply With Quote
Old 03-30-2016, 09:27 PM   #16
renfield90
The Stig's German cousin
Haven't modified the tune much besides load limits and quiet start. Probably could use more tweaking but since I'm basically not knocking, I haven't felt pressed to put time into it.
I don't have a datazap account setup yet but I should figure that out sometime...
Old 04-01-2016, 12:30 AM   #17
BurnetRhoades
BurnetRhoades's Avatar
Drives: 2013 "Hot Lava"
I think I got a bad batch of gas last night when I filled up from half a tank. Previous couple weeks I'd been .97-1 IAM at first running 91 Oct. Stage 1 as I had remaining bits of 90 and 91 from a trip out of town that were at the bottom of a 93 fill-up once back in Austin. A day or so before installing my JDL UEL I bumped to 93 Stage 1 and then 93 Stage 2 immediately after the install.
A week or so it's doing great, .97-1 IAM and I run that first tank on the UEL down to half last night and fill up on the way home. This morning it feels off, coinciding with this being the first truly warm day since I've been running OFT.
I hooked it up at lunch running errands and noticed very high intake temp 5-10F above what my dash showed as ambient temp and my IAM was dropped to .7 and I saw it rise to .82 by the time I got back to work. On the way home it was back down to .7 and only went back up to .71 and I could really feel it. I did a short log and sure enough I caught some knock in the 3-3.5K range, damnit. Gonna drop back to 91 Stage 2 and see if that clears it up.
It also looks like, based on my ECU number, that I will want flash back to stock, un-marry and get the dealer to flash in a later version and try this again
2013 Hot Lava FRS :: OFT Stage 2+ :: JDL UEL Catless :: JDL Over-Frontpipe :: GReddy Evolution RS Catback :: Enkei "Tarmac Black" RPF1 :: Tein Flex-Z Coilovers :: 245/35r18 Conti DW :: RS*R R-LCA :: Racer-X Fab R-Toe Arms :: Mishimoto Intake Tube :: Mishimoto Oil Catch Can :: JDL FSTB :: Raceseng "Slammer" + RLO :: Diode Dynamics HID + Tail-as-Turn + DRL :: 5:AD Spoiler ::
BurnetRhoades is offline   Reply With Quote
Old 04-01-2016, 05:22 AM   #18
steve99
Flashing the 91 tune wont help if knock is below 5000 rpm as the only difference between 91\93 tune is timing above 5000.
you will need to mod tune as per the tune tweaks link below , see the links to moding tune for 91 fuel
the oft tunes are based on latest compatable stock rom for your car so getiing delaer reflash will not help with your knock. Also all stock tunes are the same its jist utility bug fixes no power or performance mods right up to latest F40C roms
Old 04-01-2016, 09:17 AM   #19
BurnetRhoades
The knock just started based on some suspicious timing. You mod for transient issues that might change again with the next tank of gas from a different source?
The dealer reflash would be because the stock flash and the mod flashes I'm using are based on versions from 2013 that have the injector seal failure issue. I'm looking to correct for that and not have the motor pop and then have to explain why the OFT isn't responsible, or do all the flashes fix these issues as well?
Old 04-01-2016, 10:43 AM   #20
HLHachiRoku
As far as I have been reading even the "stock" flash from the OFT guys/gals fixes the issue with the seal failure. So that includes all the ofs maps from them. I could be wrong, but I swore I read that somewhere here on the forum ^.^
Old 04-01-2016, 11:31 AM   #21
BurnetRhoades
Yeah, I want to say that I've read as much but I've also read it suggested getting the the updated OEM flash that fixes it and any other issue. I'd want to know for sure.
Old 04-01-2016, 01:34 PM   #22
choiboie
Drives: 2013 Fr-S UltraMarine
didn't want to make a new post wondering if anyone here could just help me out.
oft is coming today in the mail. before i even hook up the oft, should / do i need to drive the car around for a lil. haven't started my car today it's been sitting in the garage all morning.
choiboie is offline   Reply With Quote
Old 04-01-2016, 01:47 PM   #23
eggncheese
Drives: 2013 Ultramarine Scion FRS MT
You don't have to drive it before you write your stock ROM to the OFT. You battery should be fine assuming you haven't let it sit for an extended period of time without running it. I suggest you take a look at this thread, the "First Use" section in particular:
http://www.ft86club.com/forums/showthread.php?t=71157
eggncheese is offline   Reply With Quote
Old 04-01-2016, 02:14 PM   #24
choiboie
Thanks!!!!
Sent from my SM-G920V using Tapatalk
Old 04-01-2016, 02:14 PM   #25
choiboie
just came in!!!!
Old 04-01-2016, 02:54 PM   #26
eggncheese
Have fun @choiboie !
Old 04-01-2016, 03:29 PM   #27
choiboie
so before I hooked it up to my car.i made sure to update the oft from my laptop.after that.i did the normal install..plug in oft.turn ignition to on. Pick gt86. Then read..it'll keep getting this error
Old 04-01-2016, 04:19 PM   #28
steve99
if your cars original ecu calibration was
400C, 700C, A00C, A01C,B00C the oft rom you flash will actually be a B01C version (or the equitant D version if your auto). even thoug it may be labelled with your original calid, ie with the oft rom your already on the latest flash.
note you may see your old rom calid like A00C or something but the actual rom in car is based on B01C.
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 04:02 PM
R/T Tuning & R/T Tuning Speed Shop Review Thread R/T Tuning User/Vendor/Sponsor Reviews, Feedback, Comments 37 10-03-2014 02:23 PM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 03:15 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 06:33 PM
