Old 03-17-2016, 02:47 AM   #15
thecarfilmer
IG: @nickwiththefrs
thecarfilmer's Avatar
Drives: 2016 Scion FR-S Halo
but I already did
Originally Posted by swarb View Post
don't?
thecarfilmer is offline   Reply With Quote
The Following User Says Thank You to thecarfilmer For This Useful Post:
go_a_way1 (03-17-2016)
Old 03-17-2016, 03:43 AM   #16
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Did I think this thread through before making it?
- The Ancient BRZ Sacrament
by Zaku
The Following 6 Users Say Thank You to Guff For This Useful Post:
Captain Snooze (03-17-2016), cdrazic93 (03-17-2016), go_a_way1 (03-17-2016), MisterSheep (03-17-2016), Tectoniic (03-17-2016), thecarfilmer (03-17-2016)
Old 03-17-2016, 05:10 AM   #17
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
lols
Old 03-17-2016, 05:35 AM   #18
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
No.
what should I eat as a snack?
The Following User Says Thank You to cdrazic93 For This Useful Post:
Old 03-17-2016, 07:18 AM   #19
Why am I the only one that has answered properly so far?
(Snooze does not count because he was playing with himself)
Old 03-17-2016, 08:27 AM   #20
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Okay, okay. It's Nevermore to the rescue.
My application is like 99% DD so I know a lot of aggressive modding isn't necessary, but there's still some stuff I want to do. I know nothing about tuning and the last time I asked a question in the subforum it didn't end well, so my question here is pretty simple. I had always thought I was going to have a custom dyno tune from a shop, but it's looking like that might be too expensive, and pointless for my application. Would it make more sense for someone like me to just get like OFT or something along those lines and use their premade maps?
Nevermore is offline   Reply With Quote
The Following User Says Thank You to Nevermore For This Useful Post:
Old 03-17-2016, 09:06 AM   #21
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Answer:
For someone like you who has no tuning experience I would recommend an off the shelf open flash tablet tune. Its basically plug and play so its easy for you to do. If you still think oneday you might want a custom dyno tune I would recommend ECUTEK. It is a litte more advanced but has a few more features and more tuners support it.
TL;DR:
Yes get OFT
Random comment:
Come on guys this thread/game will be fun if we all try.
The Following 2 Users Say Thank You to go_a_way1 For This Useful Post:
Nevermore (03-17-2016), Tectoniic (03-17-2016)
Old 03-17-2016, 12:10 PM   #22
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Answer:
TL;DR:
Yes get OFT
Random comment:
He gets a +1.
Next question involves camber. I am planning on using springs (RCE yellows) and will be getting camber bolts in case I need adjustments. My question is this, the rear is not adjustable with LCA, and I don't want to buy them, so should I just have the shop doing the alignment zero out the toe (seen this mentioned numerous times) and match the front camber to whatever the rear lands at, or are the front and rear supposed to have different amounts of camber? I'd think it should be square.
Old 03-17-2016, 12:20 PM   #23
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
He gets a +1.
Okay you will get camber in the rear just from the drop but it shouldn't be too much. You will want more negative camber in the front then in the rear. More front camber vs rear = oversteer, more camber rear vs front = more understeer. Thats why the factory alignment calls for more rear camber then front, its a safety thing for normal drivers. You also want 0 toe for tire wear on a DD.
TL;DR Go with more front camber then rear if you can for better response and handling
Old 03-17-2016, 12:21 PM   #24
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I answered Guff's question too (you can have more then 1 answer)
He gets a +1.
You need more camber up front, but running similar camber front/rear is fine. Get SPC camber bolts and run them up front with around -2 degrees. The rear should be a little less dropped on Yellows. Just get the alignment and post the specs but I would think you will be good woth that (I was on Yellows and so are many other people). And yes zero toe
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
go_a_way1 (03-17-2016), Nevermore (03-17-2016)
Old 03-17-2016, 12:29 PM   #25
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I didn't make the thread, nor do I know all the rules, but I'm going to say they both get +1.
The Following 2 Users Say Thank You to Nevermore For This Useful Post:
go_a_way1 (03-17-2016), Guff (03-17-2016)
Old 03-17-2016, 12:51 PM   #26
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Points are all made up just for fun and we arent keeping track. This is a good place for people like me to help people like you with random small questions like those
Old 03-17-2016, 12:54 PM   #27
mixtape
Posts in the nude
mixtape's Avatar
Drives: 2016 WRB BRZ
How do I properly quote a message on this forum?
Does answering your own question count?
2016 Subaru BRZ - World Rally Blue [Build Thread]
Instagram: @mixtography | My Automotive Photography
"Lesbian trees have no wood." - Scoobs McGee
mixtape is offline   Reply With Quote
The Following User Says Thank You to mixtape For This Useful Post:
Guff (03-17-2016)
Old 03-17-2016, 12:54 PM   #28
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
What should I have for lunch today?
Instagram: trevor.parque
The Following 2 Users Say Thank You to MisterSheep For This Useful Post:
Random pictures thread! switchlanez Off-Topic Lounge [WARNING: NO POLITICS] 8545 04-10-2020 02:58 AM
RANDOM QUESTIONS THREAD 70NYD AUSTRALIA 198 05-25-2015 10:03 PM
Introduction/Random Questions AZbrz89 Arizona 4 01-03-2015 08:51 PM
Random Picture thread WheelFast Other Vehicles & General Automotive Discussions 2 01-16-2012 03:28 AM
