#15 | |
Boost Creep
Drives: 2016 HyperBlue BRZ
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
#16 | |
Intrigued by what other functionality the little black box can provide! Also waiting on the iPhone app!! |
#17 | |
PhoneFlash by EcuTeK
Cheers, William Knose Delicious Tuning |
#18 | |
Boost Creep
#19 |
#20 |
Drives: Late 2014 Subaru BRZ
Not to revive this thread but, cant we just tap the sensor wire only and feed the gauge to its own 12v and ground so the ethanol sensor isnt affected? Im too intrested in a real gauge pod not app.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#21 | |
Boost Creep
Essentially, the ECB-1 can be considered to be its own flex fuel kit minus hose and one wiring harness. Basically, the sensor is a standard GM sensor that outputs a mixed voltage/PWM signal that the car can't understand. The ECB-1 translates that signal into a simple 0-5Vdc signal, from 0-100%, which can be found on the brown wire coming off the gauge. ![]() If you were to run this wire to the rear O2 jack found on the front passenger side of the engine block, and have your tuner make a custom map based on the above table, you have flex fuel.
#22 |
I just found the factory delphi 3 pin male and female connectors on ebay. Im going to order them and male a small extension cable so i can have a splice free gauge setup. Ill just use the a cigarette lighter power plug and access a 12v behind the glove box for the gauges power like I used on my wideband.
Connectors: Part #15326808 and #15326813 Terminals: Part #12191819 and #15326269 Seal: 15366021 This should be useful and fill my empty gauge pod hole.
2014 Subaru BRZ
#23 |
Finally found it. Kind of just have to Google flex fuel wiring. It applies to just about any car.
The MTX-D will work. It reads without any other computer the 0v 0 ethanol and 5v 100% ethanol. Might need to tap right before the 02 sensor plug for a good signal.
2014 Subaru BRZ
#24 | |
Boost Creep
The reason I ask this, is that to achieve the correct stoichiometric mixture with any amount of E requires more fuel, so it's better for it to be 5V at 0% and 0V at 100% (or 85%). Better to run rich than lean if the signal processing fails.
#25 |
Ya i have delicious tunings kit. Kills me that it doesnt have an option for a real gauge.
Confirmed from my tuners ecutek flex fuel video the ecu reads 0v - 5v like the gauge to pull the values of ethanol. I respect the forum rules not to link or give adds to unsponsored or banned members. I do think this topic not been resolved in a timely manner is counterproductive for the development the future of the GT86.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe Last edited by GsxrMe; 12-18-2016 at 07:51 AM. |
| Innovate Motorsports SCG-1 Boost Control and AFR protection gauge... Now Available! | Innovate Motorsports | Forced Induction | 19 | 07-16-2014 04:24 PM |
| Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 24 | 09-20-2013 03:04 PM |
| Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 05:55 PM |
| Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 1 | 09-13-2013 01:34 AM |
| Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK | DeliciousTuning | Announcements, Contests, Giveaways | 5 | 08-26-2013 02:33 PM |
