Old 03-09-2016, 07:42 PM   #15
humfrz
Originally Posted by S84kam View Post
that doesn't damage our spark plugs right? because everyone knows how much of a pain in the ass they are
I reckon not. With the coil sitting on top of the plug firing away and 12:5 compression hammering it from below, I doubt a plug is going to foul .....
humfrz
Old 03-09-2016, 07:47 PM   #16
humfrz
I don't see much mystery here. Circumstantial yes but may be something as simple as a not quite tight enough cable or slightly dirty connection.
Now @Tcoat ...... that is waaaaaay to simple ........
We got us a highly complex problem working here .......
humfrz
Old 03-09-2016, 08:15 PM   #17
Ultramaroon
not playing cards
Ultramaroon's Avatar
humfrz
Old 03-09-2016, 11:07 PM   #18
TMW
Drives: 2013 Subaru BRZ
if i remember correctly, this is an uncommon issue with some of our cars. By no means am I an expert, definitely a car noob, but i believe it has to do something with the positioning of the camshaft after turning off the vehicle (read something about this like a year ago, cant remember much about it though). Most comments I've read about this doesn't seem to indicate a major mechanical issue with the car. This same scenario happened to me maybe twice since i've owned my car (2 years). Pretty random, no real pattern to when it happens. Happened sometime the first month I had it. Got the second one about 4 months after that. None since then. Will probably happen again, but who knows. I would just do some searches to see if you can find anything. I would like to know more about this as well if anyone else has more info.
TMW is offline   Reply With Quote
Old 03-11-2016, 07:34 AM   #19
iRazor
Drives: 2013 brz 2008 wrx
Did the dealer keep the car overnight? Did your car sit overnight for this issue to occur?
Sent from my SM-G920V using Tapatalk
iRazor is offline   Reply With Quote
Old 03-12-2016, 06:47 PM   #20
S84kam
S84kam's Avatar
Drives: FBRZS
when this occurred, it did sit over night for this to happen. I had started the car and reversed so my wife could park in the driveway and then i shut the engine down. It was quick and only moved a couple of feet, i do this all the time. Next morning, No start
S84kam is offline   Reply With Quote
Old 03-12-2016, 07:37 PM   #21
S84kam
S84kam's Avatar
Drives: FBRZS
I'm not leaving my car overnight with them. I watched my dash cam footage of their "8km" test drive (i asked wtf why did you test drive it when it started fine) they replied to make sure it doesn't shut off automatically while running...
I told them, my issue was NOT STARTING. This is why i have no faith in stealerships... Im already starting to believe consumer reports was totally right with their prediction, this engine is unreliable
Old 03-12-2016, 11:40 PM   #22
BRZnut
Drives: BRZ DGM Limited
Hey..in the situation as you describe above I have had hard starts with other fuel injection cars that I have owned. This happened with my '95 maxima and 2000 I30 (same engine design), even when new. I have notice a harder than usual start with my BRZ in those situations too, but nothing too bad. When I researched it, what I determined is that with a start the injectors add more fuel than usual and if you quickly turn the car off that can leave excess fuel in the cylinders which makes it harder to start the car the next day. Almost like a "flooded" engine as others have mentioned above.
Old 03-15-2016, 09:25 PM   #23
iRazor
Could also be leaking injectors. Pressure builds key on. Turn car off pressure still holds until leaking past injectors.
Old 03-18-2016, 08:22 AM   #24
Elkton86er
Elkton86er's Avatar
Drives: 2014 Subaru BRZ Limited WRB AT
Absolutely also had this same experience with my wife's 2012 Hyundai Tucson. Started it - moved a foot - shut it down. Then no start. The problem is exactly as described - fuel pump during the start sequence adds too much fuel and floods the engine. My understanding is that all fuel injected cars can do this. I have since kept this in mind when moving cars a short distance - I ALWAYS let the engine run for at least 30-60 seconds before turning it off. Have not had any issues since I started doing this.
Cosworth Drop-In Air Filter, Diode Dynamics DRL module, Perrin Tips
Elkton86er is offline   Reply With Quote
Old 03-18-2016, 09:33 AM   #25
DJCarbine
Thupercharged
DJCarbine's Avatar
During cranking/no start condition do you see the RPM needle bounce at all
2013 FRS
Vortech V3 11psi
Old 08-27-2016, 05:30 PM   #26
S84kam
S84kam's Avatar
Drives: FBRZS
I haven't had a problem yet after seating the filter perfectly!!
So, in March. I installed a new air filter this time I removed the entire box and seated it correctly. So far I've been trouble free. I think the dealership has been installing it wrong without removing the entire box out. There was usually a gap
I'm not 100% sure but. I've been driving it everyday so far with no more issues.
Old 08-30-2016, 07:43 AM   #27
Cole
Not a troll
Cole's Avatar
But it's definitely the engine that's unreliable, and not a poor craftsman, right?
starting out dmitri93 Scion FR-S / Toyota 86 GT86 General Forum 30 07-11-2014 12:06 AM
Rev when starting ? (Possible and why ?) Simon99 Software Tuning 11 05-22-2014 04:12 AM
just starting out mortachi Cosmetic Modification (Interior/Exterior/Lighting) 3 10-06-2013 10:23 PM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Starting it off e10rice Mid-Atlantic 93 03-26-2012 03:16 PM
