#15 | |
Drives: BRZ. R34 GT-T
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
| The Following User Says Thank You to olsonpg For This Useful Post: | Tcoat (02-14-2016) |
#16 | ||||
Long term there could definitely be ill effects, the IAM (ignition advance multiplier) should be at 0.7-1 on 91 or 93, it must drop well below that in order to counter the knock and sometimes that doesn't even work. It can only detect and change that when the knock occurs as well. At that point you're increasing the probability of pre-detonation because the ECU can only adjust so much after a knock occurs.
#17 | |
Drives: '11 Cayman , '14 Camry, '11 Tacoma
| The Following 2 Users Say Thank You to billwot For This Useful Post: | FRSBRZGT86FAN (02-14-2016), Tcoat (02-14-2016) |
#18 | |
#19 |
Drives: Stock
I was having some off the same issues but also seemed as if the handing was off too. And I know this seems crazy but I check my rev limiter setting and it was set at (--00) wtf?!? Yea that's right it like it was set at all so I set it and turned on the shift light and trans number display and now she runs like the day I got her. Crazy huh!! Also she steers so much better?!? Don't know why but check it just in case maybe it's a programming problem?
| How Much slower is current F1 | Joakim3 | Other Vehicles & General Automotive Discussions | 21 | 12-03-2015 02:07 PM |
| Is this normal? | BlackyRose | Engine, Exhaust, Transmission | 8 | 10-04-2013 12:54 PM |
| Passenger/Right Rear-View Mirror Slower then... | SPEEDGOD | Issues | Warranty | Recalls / TSB | 3 | 07-30-2013 11:54 AM |
| Is it normal to see a .... | Mango22 | BRZ First-Gen (2012+) — General Topics | 10 | 10-12-2012 03:54 PM |
| AT officially 1 sec slower than MT at Tsukuba | madfast | Engine, Exhaust, Transmission | 42 | 05-22-2012 05:24 AM |
