#15 | |
Drives: The "L" train
You dont seem to understand what octane does in a fuel. Higher octane prevents detonation. It burns slower and more controlled. That allows you to run more ignition advance and/or boost in an FI car. That's what makes more power, running more agressive profiles - profiles that would damage the engine otherwise with detonation. You dont benefit any from running 110 octane over premium as that is what the factory tune is done on. The ECU isn't going to run a more aggressive map than the one meant for premium because there ISNT one programmed. Even if you went to the dyno and extracted as much power as possible from that fuel you're not going to net much of anything over premium without rebuilding the engine with much higher compression pistons for a higher static CR or boosting the hell out of it.
#16 |
Drives: '06 AM V8V Coupe
#17 | |
So honestly... probably no difference in reality. |
#18 |
The owner's manual says fill with 93, 91 is okay if that's all you have, but you may hear slight knocking. If the manual admits that you may get some knocking with 91, then I think it's safe to say there should be a small difference, easily perceptible or not.
#19 |
Again, only if you actually knock and the ECU detects and retards timing. There's a whole lot of factors involved.
#20 | |
BAMF
| 93 Octane | Smokinbuffalo | Northwest | 20 | 09-02-2012 05:24 PM |
| 93 octane called for - who sells? | Sport-Tech | CANADA | 107 | 07-26-2012 12:26 PM |
| Break-in Period and Octane level | MattM232 | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 06-05-2012 11:00 PM |
| 93 Octane? | ashtray | BRZ First-Gen (2012+) — General Topics | 175 | 04-04-2012 12:22 PM |
